Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 25th March 2005, 01:54 PM   #1
Default 250w ballast powering 400w bulb
i think i read somewhere on this site that i could power a 400w bulb with a 250w ballast, but not powering it the whole 400w just only 250w.
is this true
Old 25th March 2005, 03:38 PM   #2
dang i still cant find the post
Old 25th March 2005, 03:52 PM   #3
Inkog is offline Inkog  United States
Take this with a grain of salt, as I'm harly an expert on this subject...
I would think that the inital high voltage discharge may be too low to start the bulb. I also think that the power supplied to the bulb may not be enough to keep the arc alive reliably, if at all. I bet it wouldn't be good for your ballast either.
But what do I know , It may work fine. Only one way to find out.
Why not use the correct bulb?
Old 25th March 2005, 04:01 PM   #4
well i can get 2 400w t-15 style bulbs for only 24 dollars
Old 25th March 2005, 04:04 PM   #5
pinkmouse's Avatar
The ballast will likely glow brighter than the lamp...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 25th March 2005, 05:54 PM   #6
cbm5 is offline cbm5  United States
Ha, nice one pinkmouse!
Old 27th March 2005, 12:05 AM   #7
Dr.Du is offline Dr.Du  United States
Default Been There Tried that don't work...........BUT
one way it can work is if you have access to a 150 watt ballast you can wire the 150 + 250 in series and that will work..........that's my current set-up and works beautifully.
Old 27th March 2005, 12:25 AM   #8
alright that sounds good i think im going to do that.
how is it wired.
do u have a pic or anything
Old 27th March 2005, 12:29 AM   #9
justme is offline justme  United States
Well since we seem to be talking about non-standard configurations I have a question.
Can a ballast from a pro pj that was powering a XXX Watt lamp be used to power one of the longer lasting and cheaper ones? I seem to remember Ace saying that they couldn't because one used AC and the other used CD but this site says that MH lamps are very rarely operate on DC:
http://members.misty.com/don/dschlamp.html#dlbas
"There are a few specialized metal halide lamps that are made to work on DC. These often have asymmetrical electrodes and/or short arc lengths. These lamps often also must be operated only in specific positions, and only with the type of current they were designed for in order to achieve the proper distribution of active ingredients within the arc tube and to achieve proper electrode usage."
They explain that you really need the correct voltage as well as the correct wattage to operate these lamps.
Can anyone clarify this? And can you check the voltage of these with a multimeter (after the initial pulse that starts the lamp)?
thanks
I thought I was a genius until I met one.
Old 27th March 2005, 03:21 AM   #10
im really thinking about this 150w ballast with 250w ballast. theoretically it seems as if it would work. it equalls 400w and it will put out that much. but i just dont know.
hey dr. du is it pretty effecient
400w MH Ballast kit with BULB! cooldrums Swap Meet 0 20th November 2005 11:39 PM
FS: 250w Bulb/Ballast and Projection Panel slizm Swap Meet 23 7th March 2005 02:39 AM
Page generated in 0.09380 seconds (77.67% PHP - 22.33% MySQL) with 10 queries
