Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 25th March 2005, 12:17 AM   #1
Send a message via MSN to mindless_fool
Default these specs ok for a 7" projector
got a monitor by myron & davis ment for a car..i took it apart and it should be ok...i just want to know if the specs on the monitor or ok..here they are:
* 7.0" Active Matrix Display 16:9 Wide Screen Ratio
* Resolution: 1440 x 234
* Viewing Angle: Left/Right:65 degree,
&nbspTop: 40 degree, Down: 65 degree
* Brightness Rating: 300 cd/m2(NIT)
thanks for any info guys
Old 25th March 2005, 01:14 AM   #2
ancorp is offline ancorp
Hey,
Looks like an ordinary low res 7" screen. The resolution is usable but not something too great. Its actually 480x234 (RGB). Consider this - NTSC dvds are 720x480... thats over 3 times the resolution!
Still will give a watchable picture, and a great starter LCD.
How much did you pay (in canadian ofcource ), and where did you buy it?
Currently used display:
NEC XG110 HDTV CRT Projector
90" lenticular silver screen
Current Audio setup:
Fronts - Realistic Mach One (FREE!!!)
Sansui SP- 5500x (with new woofers - free woofers!!!)
Center - dB+ studio monitor
Rears - Kenwood LS 70's
Hitachi HSP-MS53's
Sub - Acoustech Labs S100ETH
AMP - Insignia IS-HC040917 (cheap but does the job)
Gotta love 4 15" woofers!!!
Old 25th March 2005, 02:23 AM   #3
179 at canadiantire
http://www.canadiantire.ca/assortmen...=1111717743803
how big of a screen do you think i can get to watch it comfrotably?
im thinking 50-60 inches? or is that too big for the low res of the screen?
Old 25th March 2005, 03:56 AM   #4
Hmm... does it atleast have S-video input?
I think it would be just fine up to 80" (depending on your viewing distance, even 100" can look great if your'e far enough).
If I were you, I would have gotten a 15" lcd and used that. I think there was a decent one for only $199 in Staples Business Depot before? I could be wrong...
Good luck on your project!
Cheers
Alex
P.S. what area in the GTA are you? I never heard oof anyone talking, showing, making or doing anything with diy projectors but me...
Im in Vaughan.
Hitachi HSP-MS53's
Old 25th March 2005, 04:26 AM   #5
im near yorkdale mall....i went with a 7" cause i want to make something rather small..those 15" are kinda big...i saw that staples promo..it was limited time...and a while back..i just missed out on it oh well....i can always return this one..got it 2 days ago and just get a lilliput off ebay or something...
Old 25th March 2005, 05:00 AM   #6
Yea, I guess the Lilli is your best choice. Beware, there is a 7" Lilliput thats cheaper that has the resolution as low as this one.
Alex
Hitachi HSP-MS53's
Old 25th March 2005, 02:32 PM   #7
i think im going to just use this one and see how it goes to use it as a test lcd...i can always use it as a monitor for tv later or something...and get a liliput then...
Thread Tools
Alps RK40 pot aka "black beauty" specs? h_a Parts 2 28th January 2007 08:48 AM
"Apple Pro Speaker" specs? Spasticteapot Multi-Way 13 18th October 2006 08:11 AM
Is this right - "critical Q sub specs" ? RobWells Subwoofers 3 30th January 2005 01:28 PM
Specs for "Audio Gods" woofer? Jonathan Bright Car Audio 1 13th March 2004 05:47 AM
Page generated in 0.22134995 seconds (80.17% PHP - 19.83% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
