im posting a picture of my projector that is unfinished. i need to know where i should cut holes for the fans. where should the fans go.
and also what tool should i use to cut fans |
#2 |
pic 2
#3 |
I can't really help you with the exact placing of the fans (a diagram of your pj would help) but there are a number of considerations:
1) They must provide adequate airflow over components like the LCD and the lamp, and the ballast if it runs hot 2) Usually a push pull configuration works well. One fan will provide the intake of cool air and another will provide the exhaust 3) Bear in mind that hot air rises 4) Light leakage is another consideration. You can solve this by using vents As for cutting the holes use a large drill bit sufficient for a jigsaw and then just use the saw to cut out the hole. |
| Cutting holes in aluminium enclosures | emperor | Parts | 4 | 22nd July 2007 08:45 AM |
| cutting speaker carpet around recessed driver holes | noodle_snacks | Multi-Way | 13 | 17th June 2006 08:43 AM |
| Cutting Nice Holes | jwatts | Multi-Way | 10 | 9th February 2005 01:46 PM |
| Is Rotozip a good tool for cutting holes? | AJ Bertelson | Multi-Way | 10 | 9th June 2004 08:36 PM |
| Best method for cutting driver holes? | dc | Multi-Way | 16 | 29th May 2002 01:27 PM |
| Page generated in 0.06235 seconds (71.44% PHP - 28.56% MySQL) with 11 queries |
