#41 |
i finally added a cover for the objective to secure it from dust, while the beamer ist not in use...
#42 | |
Hey Slize,
What a great job man !!!! it is a very pro design ... congratulations I have a question for you of an old topic you posted in this forum that I found trying to solve my projection size. Its about the solution you did to solve your short focal length using an eye glass lens, quere is my situation: I made my projector with a 5" PS1 LCD and used the fresnels and triplet of an 3M ohp, both fresnels are 330mm FL and the triplet is 330mm FL too. The room where I will use my projector just allow me a throw distance of 2.4mts between the triplet and the screen so that give me a 32" image. In your summary post you mentioned this: Quote:
- Triplet lens with a fl of 330 mm = 0.33 m = (1/0.33) 3.03 dioptrien - My object size should be 1.524 m (diagonal) - My throw distance is 2.4 mts so my ideal lens would have an fl of 180 mm = 0.18 m = 5.5 dp that means my adiotnal lens must have 5.5 - 3.03 = + 2.47 dp Can you tell me if these maths are right? Can the result be a positive dp(+ 2.47 dp? The lens must be for a farsightly or short-sighted person? Thanks in advance !! |
#43 |
Slize,
Just saw your project. Great execution. Very well crafted. Hezz |
#44 |
One of the best designs I've seen! Great work
#45 |
up
#46 |
100% agree with everibody. COngratulations,
just wonder, what size is the screen? |
#47 |
As he stated his screen was "diagonal 1,90m (75"), 1,50m (60") wide and 1,10 (43") height", I guess you ask about his Toshiba 10,4" lcd.
From the pdf official specsheet (can't find a link to it in english right now, only in german, so no worries...). Outline: 241.5W, 171.9H, 5.5D. Active area 210.432W, 157.824H. In mm of course. I've got the toshiba 10.4" stripped next room so I can check it if you want. |
#48 |
sorry i didnīt read it. So it is 74" diagonal screen;
74/10,4=7,1 magnification focal=34,5 then lcd-triplet distance (D) should be 1/34,5=1/D+1/7,1D D=39,3cm so 7,1x39,3=280cm throw moreless. Now, 39,3cm and 10,4" lcd has 37 degrees field angle from the triplet. Its a very good setup, mean the lens is working on good contitions. I believe you have very good focus in full image. |
#49 |
That is a fine looking projector. I think anyone would be happy with that in their house. Good Job!
I like the use of curves and balance to the shape. Very artistic. Also very efficient use of space. I think its the best ive seen. Have a well deserved cold one dude |
#50 |
Thats one of the best projectors i have even seen
Shame mine dosent look anything like it |
| 12.1" 250w kit to part out | MrPerfectionest | Swap Meet | 11 | 22nd May 2005 04:37 PM |
| Page generated in 0.11683 seconds (77.95% PHP - 22.05% MySQL) with 11 queries |
