I've been looking around the net for a while on how to make a video extender. Something that can take a VGA signal from a computer and possibly run it over 400ft of cable without the ghosting which happens after about 6ft.
There's plenty of products available like this one http://www.altinex.com/Products/Dist...0CT_center.htm whic do this sort of thing but they seem a bit on the expensive side. I've also tried using cat5 to transport the vga signal without any active components and while i did get the signal to an astonishing 12ft it's still no where near long enough to get to the projector on the roof. What exactly do these boxes do? Is it possible to easily build one? I assume if they just amplify a video signal that simple opamps with sufficient bandwidth would suffice however, I doubt this is all that simple. Any ideas? |
#2 |
I havent tested or even attempted to test this, just thought of it now, but what about using 4 CAT5 cables, or one multiconductor cable, exten the sync wires directly, then use 3 8-bit ADC's one for red, green, and blue, use a cat5 for each, then three 8-bit DAC's on the projector end, seems like it should work
#3 |
well technically it would be 5 since there is Y rY and bY, Hsync and Vsync in the vga standard.
However in practice i doubt that they convert the signal from analogue to digital, and then back again. The main reason for this, wouldn't the high bandwidth of the video simply cause problems for this in the first place? I can imagine there would be significant loss in the ADC - DAC process. |
#4 |
You can get good quality VGA signals through an actual high-quality VGA cable designed for long runs. These cables have a separate coaxial cable inside for each R, G, B, and sync. I've regularly used runs up to 50 feet without significant degradation.
Otherwise, you will need a device like the Cybex Longview to get the signal any further. |
#5 |
actually I just found another site wich recomends STP and shielded terminals as a requirement for this application.
I'll try that next. |
#6 | |
#7 | |
That is solved easily by terminating the lines properly. Why 400ft? Wouldn't it be easier just to have a cheap pc by the projector, and run that pc via your ethernet using a remote desktop utility?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#8 |
The projector is on the roof why? So people don't trip over it, so it doesn't obstruct things etc. It's the design of the room. It looks good this way, if it could be functional via vga too it would be even nicer.
I don't need 400ft, but the computer is a significant distance away. I mentioned 400ft, because that's how far the devices i've seen do this have stated. I always thought that these contained active parts to amplify the signal or something, however the one i've looked at recently says you can achieve sending a 1280x1024 signal over 100ft only using STP. I did try running an SXGA signal over UTP but it just left us with a ghosting image. If my 15pin -> STP converter doesn't work I'll be back to square one. |
#9 | ||
#10 |
Yes ceiling that's what I meant.
The UTP ends are terminated properly, each colour is combined with a gnd for that twisted pair, and hsync is combined with vsync. Apparently though STP is the only way this will work over long distances. I'll try this asap. |
| AV IR over Cat5 (simple audio/video repeater for Sky, Digital Tv and Tape recorder) | audiodesign | Solid State | 0 | 24th June 2009 02:28 PM |
| "Free" Toslink/S-Video and cheap CAT5 | tommak | Vendor's Bazaar | 0 | 2nd January 2008 06:06 PM |
| Video over cat5? | coolpoppa | Everything Else | 2 | 22nd September 2006 05:23 PM |
| DVI video cable using CAT5 wire? | montreal | Digital Source | 0 | 7th September 2006 06:20 AM |
| Page generated in 0.11861 seconds (77.36% PHP - 22.64% MySQL) with 10 queries |
