Go Back   Home > Forums > > > >
Help with InFocus LP340
Old 19th August 2013, 09:12 PM   #101
SubaruB4 is offline SubaruB4  United States
It looks like this btw
Old 19th August 2013, 10:54 PM   #102
Gcalo is offline Gcalo
Mouser P/N: 511-VIPER100A-E
www.mouser.com
They are about $5.00 each
Old 19th August 2013, 10:59 PM   #103
Not going to work did you see the picture I posted that goes on the board it's 8 leads thanks for your help anyways
Old 19th August 2013, 11:02 PM   #104
What model is yours?
The part number I posted is for the 7200 series
Old 19th August 2013, 11:06 PM   #105
I have the IN116
Old 19th August 2013, 11:13 PM   #106
Sorry I thought we were talking the 7200 series in this thread
Was not following every page.
If you contact Mouser and give them the #'s off that device they will research a suitable Xref for it
Old 19th August 2013, 11:16 PM   #107
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Originally Posted by guennede View Post
Hello, my LP540-Powersupply is dead,
no 5V,3.3V....
High Voltage for the Bulb-circuit is ok.
I changed all caps, optocouplers, the TOP245YN-switching-circuit.
-> no success
Measuring with oscilloscope between Gnd and Drain of the TOP245YN shows very short pulses.
In my opinion, the transformer (CR 0351 573900917) is short circuited at the primary side...
any idea, where I can get a new powersupply, or a new transformer?
Signs on PCB:
E158063 KW0348
410-1828-20
any idea for a schematic?
Thanks in advance
I have never heard of a transformer going faulty in one of these or any Sanyo, Philips or Sony unit. Look for a short circuit diode in the secondary. If a diode is S/C then the power supply will hit over current and shut down, trying again as the equilibrium builds again.
If you can't get it fixed, I will do it for you.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 20th August 2013, 03:17 PM   #108
Just what I thought Mouser would do.. They do have the MR4010 listed but they require you to buy 350 of them at $1.93 each and it has a 12-14 week wait.
That's what they sent me in the quote.
Old 20th August 2013, 08:10 PM   #109
mbates14 is offline mbates14
the MR4010 is made by shindengen and they are junk. Anything made by those guys are garbage. Does Sony ring a bell? They used them and they all failed.
Most suppliers arnt going to carry that IC, you will have to look for a pin-compatible equiv or ebay the IC.
Old 20th August 2013, 08:14 PM   #110
yes I already brought the MR41010 from ebay at $8 a IC
So I know nothing about the Sony but what's bad about the chip? btw I ended up getting another projector so I can see first hand what is bad with the board when I have a working one next to it.
Help with InFocus LP340Hide this!Advertise here!
