Go Back   Home > Forums > > > >
cheapest way to make 124 inch diag screen? and can't put on wall
Old 30th November 2004, 11:37 AM   #1
pood is offline pood  United States
Default cheapest way to make 124 inch diag screen? and can't put on wall
I'm going to be getting my Benq PB6100 in the mail in a couple days...
I need a screen to project it...I've calculated from the distance where I'm going ot use my projector, it's going to make a 124 inch diagnol image (99x74)....
whats the cheapest material I can use to build this?
also there's a problem....how the room is setup...I can't have it put on the wall...it's actually going to be sitting against 2 sliding window doors to the balcony....
so, I guess something that can easily be moved and transported would be nice....what do you guys suggest?
btw, how much do the Parkland Polywall cost per square feet? or do they even go up to that size
Old 2nd December 2004, 12:27 AM   #2
Dwiel is offline Dwiel  United States
I am currently using blackout cloth. I however have not found anything that is any wider. My cloth is 48" I think. I would also like to have a larger screen, but what I have right now works. Really, its about a perfect size for widescreen. Which is what I normally watch anyway.
I might try to cut a piece of it and see if seems are visible. I'll let you know how it works.
Dwiel
dwiel.net
Old 2nd December 2004, 07:51 PM   #3
SGSeeker is offline SGSeeker  United States
yeah, blackout usually comes in 54" wide rolls so that wouldn't work unless you special order it. I don't know of any fabric stores in the seattle area that carry wider cloth, but they might exist. As for other ideas, I have none. You could always use any flat surface (that won't be folded) and put down a couple layers of paint. http://www.avsforum.com/avs-vb/ has a lot of information on screen materials and paints
Old 2nd December 2004, 08:05 PM   #4
victor-eyd is offline victor-eyd  United States
Have you tried walmart.com for a blackout screen. They sell a 105x80 single sheet @ us$55
Also go to avsforum.com , got diy screens, and research blackout aka bo or boc and search walmart.
I have the walmart 105x80 myself and there it came all wrinkly but you could steam it out yourself or when you're framing it make the pull is taught so the wrinkles come out.
Old 2nd December 2004, 08:32 PM   #5
Didn't know that, good info to have. A little expensive (compared to the 54" wide rolls), but its already the perfect dimensions and quite large at 132" before framing. My lcd is a little lower than 4:3 format and the slim borders on the sides drive me insane
Old 3rd December 2004, 01:15 AM   #6
hmm, that sounds like a good idea, but I have to frame that stuff?
I need something light that I can just hang with tape or something, heh
can you provide me a link for hte blackout screen from walmart? i cant seem to be able to find it
Old 3rd December 2004, 04:57 AM   #7
GO to walmart and look for the cloth. You may get by with calling them, but I wouldn't be surprised if you get someone on the phone that has no idea what you're talking about. Just ask for the material that "goes behind curtains to block out the light" if they don't know what "blackout cloth" is.
A frame is the best way to get the screen flat and looking good. Something such as thumbtacks would hold it up if you wanted, but tape wouldn't do anything - unless its stronger stuff. Its a good bit thicker than say a shower curtain, but not so much that it'd weigh more than say 5 lbs for the larger size at walmart
Old 4th December 2004, 08:32 AM   #8
hmm
the problem is I need to set it against this
Old 6th December 2004, 07:44 AM   #9
looks like the blinds are working well...
here's HL2 on the projector
Old 6th December 2004, 08:27 AM   #10
Jennice is offline Jennice  Denmark
Pood,
I have found a way that works for me, without framing.
My home theatre is on the first floor (where the roof also is), so I don't have more than 120cm of vertical wall height before it goes into 45degr. angle.
Also, my g/f would never have allowed me to cover a wall for this purpose, anyway
Thus, I nneded a different solution. It turned out to work quite well for me with a 230cm wide, 130cm high piece of white, coated table cloth. (The type used for picknicks and small children, which can be wiped clean easily.) The reverse side has a fine fibre/fabric texture, which is what I project onto.
Anyway... The top part of the cloth is clamped between two 20x40mm thick lengths (bars) of wood (horizontal). This wood is mounted to the wall with hooks (could be any bracket solution, but mine can be removed easily by lifting it off the hooks).
The lower end of the fabric is glued to a round piece of wood along the length of the fabric. Since this is round (28mm diameter), I can roll the fabric onto this bar. When it's all rolled up, it's secured to the top bar by a couple of straps.
It's been working for me for a couple of months now. The only thing to make sure, is that you need wide, soft straps. If you make the roll-bar (bottom) wider than the fabric, and only use straps at the ends, the weight of the bar will bend it over time, and result in an un-even load when rolled down, causing an un-even screen. I can compensate by turning my hooks once or twice in their thread, lowering or raising them, but if you distribute the weight of the bar and fabric onto a number of straps, you'll solve this problem. Mine is not perfectly even at the ends (left and right), but I don't project there.
Maybe it'll give inspiration for your own custom-made solution.
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
cheapest way to make 124 inch diag screen? and can't put on wallHide this!Advertise here!
Is there a 5 inch computer screen? Jonasa Digital Source 7 3rd November 2006 06:48 PM
Copyright ©1999-2017 diyAudio
