My LCD Projector Deadline 1 month!!! - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 1st November 2004, 03:19 AM   #11
ace3000_1's Avatar
Send a message via Yahoo to ace3000_1
Im Sorry, ive putted the price in Argentinian Pesos.
Ahh you got a great deal then, well done .
Its a shame about lcd's, they should cost far less then what they do, we all get ripped off on those at times.
Trev
"Every technique can be used in a great many ways, but mastering it, thats what realy counts."
Old 1st November 2004, 07:42 AM   #12
Trev
Speak for yourse...wait. i did get ripped off on one (in my eyes - $120) but my other panel which I don't use I got for $23 iirc. Datashow AV back before I had anything to actually project with I should find a use for that thing.
Now watch me blow $600 or so next year on a UXGA panel (unless prices don't drop enough for my expectations and stay where they currently are)
Georgie, what lcd did you get? A monitor to strip? Projection panel?
Old 1st November 2004, 10:31 AM   #13
Andronico's Avatar
Hi Georgie, thank you very much for the information.
I have the Lilliput LCD stripped, is not very difficult to do, but be very carefull with the brown flat cable ! I use the metal frame that holds the LCD to protect it (live bfourcade !).
I tested my PJ last week with all the optics in line (without any mirror) direct to a white wall and with a provisory cardboard case, it works OK. This weekend I change the layout to use a mirror in order to reduce the size. Perhaps I can test it this night
Old 1st November 2004, 03:57 PM   #14
Georgie is offline Georgie  Argentina
Send a message via MSN to Georgie
I Bought an LCD Monitor 7", lilliput like, another brand though.
The good thing about it, is that you can flip the image, so I can put the lcd screen anyway I want in the projector and then flip the image with a button.
Ill be stripping the lcd on wednesday...
Old 1st November 2004, 04:03 PM   #15
Andronico,
Yes I want to use a mirror also...It significantly reduces the overall size.
I read that you need a First Surface Mirror.
Do you know where to buy one?
And I also need a UV Filter, cause the light of the MH lamp produces a lot of UV Rays that are harmful to the LCD.
Thanks!
Old 1st November 2004, 05:26 PM   #16
Andronico's Avatar
Georgie :
I bought the first surface mirror at American Science & Surplus (www.sciplus.com). The code is #2579, the size 160 x 183 mm and the price is US $ 3.5.- They have projection lenses also.
I'll test with a normal mirror because I want to check the minimum size needed to project. And then cut the FS mirror to this size. About UV protection, I'm using a Powerstar HQI-TS 150W/NDL with UV Stop, and a 8cm. PC cooler taking hot air out. I checked the temperature of the LCD with an electronic tester with temp probe, and after 1 hour of projection the max. temp was 40 celcius grades. I think that is not bad but perhaps I can improve it.
Georgie, which is the brand of your LCD ?
P.S : you can email me directly if you want to use our native language
Old 1st November 2004, 05:57 PM   #17
Andronico,
I tryied to email you, but you seem to have the option disabled.
Let me know your adress.
My LCD is a NapoliAudio. Is the better I could Find in Cordoba. Its TFT. 1024x468
Old 1st November 2004, 06:58 PM   #18
Andronico's Avatar
Ups !
Email me to :
jesp@cma-powerpos.com.ar
Sorry
Old 2nd November 2004, 12:21 AM   #19
ancorp is offline ancorp  Canada
Georgie,
My guess that 1024x468 was a typo and its actually 1024x768.
Is that the native resolution, or is it compressed like on the Lilliput? also, when you say flip, which way does it flip, horizontally or vertically, i.e. left to right or top to bottom?
(if its left to right, thats a very useful feature, incase you want to use your projector for Rear projection, just hit the button and you got the image the right way around for rp, hit is again, and you got it right for fp!)
Old 2nd November 2004, 01:13 AM   #20
I dont know exactly, the users manual is pretty vague. It says 1024x234. I hope thats enough...is it?
4 ways:
Normal
Left to right
Top to bottom
Top to Bottom and left to right combined.
Off topic, what I've been up to for the last month.. ppia600 The Lounge 16 25th April 2009 07:53 PM
Toroid find of the month! CJ900RR Chip Amps 5 28th April 2006 05:27 AM
Thread of the month Onvinyl Everything Else 0 23rd March 2005 10:18 AM
A.C.A. NEWSLETTER - This is the Month of Analogue! skaloumbakas Analogue Source 0 17th June 2003 06:47 AM
Copyright 1999-2017 diyAudio
