Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 23rd July 2002, 06:46 PM   #401
Default undream etc.
along time ago i had a met down on one of my projector projects. i use the two boards to keep my polvarizer intact with the lcd. now i got a problem with it(see picture below). but i think if i rout a 45 dreg. at the rectangle hole perimeter for the lcd,it might help the problem with the dim edges(just need to barrow a router. see im thinking some of you guys might have the same or simular problem with the housed in lcd setup(that why i kinda wanted to see a cut section drawing).
Old 23rd July 2002, 06:49 PM   #402
sorry i forgot the pic, here it is.opps.
Old 23rd July 2002, 07:06 PM   #403
ap0the0sis's Avatar
Send a message via AIM to ap0the0sis
Default First surface mirror
First surface mirror is a mirror that has the reflective coating on the outside of it instead of behind the glass like regular mirrors.
Example: If you were to use a regular piece of mirror to bounce a projector image onto a wall you would get what is called "ghosting" (multiple images, not sharp, color fading etc.)
When you use a first surface mirror it bounces the image exactly as it is projected.
All projectors (every single one as i understand) use first surface mirrors in them to keep focus and contast rations high.
link: http://mirotek.com/images/what%20is%...e%20mirror.pdf
ap0the0sis
Old 23rd July 2002, 07:19 PM   #404
Default i thought you might find this funny.
i thought the 120v ac neg wire would work for the 12v dc ground .yes im still using the same shoot lcd cause luckly i got it fix enough to work. but i also blew out 3 fans and a computer power supply.note this was like 2 mounths ago on the day i got my lcd in from the ups. crazy
Old 23rd July 2002, 07:20 PM   #405
opps i did it again
Old 23rd July 2002, 07:23 PM   #406
ap0the0sis's Avatar
biteon,
im surprised that its still working, usually when you over heat an "IC" (the black chip that is shinny now) to the point it shines it usually burns out. looks like lightning hit your lcd module, ha!
ap0the0sis
Old 23rd July 2002, 07:30 PM   #407
the light didnt do that cause at the time i didnt have any light source. i was just seeing if it still work when i took it apart with out the original back light hooked up to it. see in ac power the curent moves back and forth, meaning you can get pwr through the neg. wire . yes im a lucky f*ck, cause that chip still works some what and i got a remote to turn on the lcd etc..
Old 23rd July 2002, 07:57 PM   #408
Default cheak this out
undream look at the red,and yellow lines.
every body that thinks a special made reflector can mak all the light go in one direction, look at the blue and yellow lines.
i think you some of you guys forgot about those blue lines.
Old 23rd July 2002, 09:04 PM   #409
Undream is offline Undream  United States
Send a message via ICQ to Undream
well, first of all, I threw away that reflector.
And, second of all, I never claimed that it was accurate, or good, or that it would even work at all. I just tried something, because, it seems like nobody ever tries anything, they just sit around and talk here
I'm going to switch over to a longways-mounted bulb (like Marklar's), and stray away from the halogen-worklight styled reflector. I'm going to try to construct a curve as similar as possible to marklar's. However, I already know that I won't be able to make one as good. I've already scavenged the local lighting supplier stores looking for a reflector like the one that Marklar has, with nothing but funny looks and them telling me "That will be $230, want us to special order it for you today?"
Its frustrating as hell.
Old 23rd July 2002, 09:39 PM   #410
where can i find a picture of Marklar reflector.i checked this whole thread and didnt find it.
Page generated in 0.14174 seconds (77.39% PHP - 22.61% MySQL) with 11 queries
