#2011 |
Has anybody explored this site to see if there could be items helpful to us DIY projector builders?
http://awi-industries.com/Fresnels.html |
#2012 |
Turns out the OHP was heating up my panel so I took out the speaker from the panel, put in an extra cooling fan, and drilled some breathing holes in the front of the panel so now it runs cooler.
#2013 |
Hi Gunawan..
my name is Puja , and i'm from indonesia to,, i need ur help for making diy projector.. i'm currently studying in singapore now.. but soon i will be back to jakarta. maybe we could meet eachother someday pls add me in ur msn messenger my msn account is poo_jkt@hotmail.com thanks a lot.. really hoping to learn from u... |
#2014 |
Banned
Anyone know where I can get a bulb for my projector? I have a Sharp XR10X. I have been reading up on tech. to remove the bulb and replace with a new one. I can not find anyplace that carries something similar.
Please help! John |
#2015 |
Hi everybody!
I'm thinking about building an independent projector based on iPod Nano (3g). It has small (2") screen with relatively high resolution (320x240) and it is very bright with standard backlight (someone built projector without ingerention to ipod: http://www.engadget.com/2008/03/03/d...oosts-utility/ ). Did anybody try to adapt Nano's lcd to use it in normal projector? How about results? I don't want to destroy display if it is bad for projector. |
#2016 |
320 by 240 is relatively high for a tiny LCD screen, but it wouldn't be very nice for the larger image want from projection. Regular NTSC TV is more like 560 by 488, for the luminance. When you try to make a standard definition TV projector with a large image you see those big pixels in the image. The 320 by 240 image will be much worse.
But it would be very nice to have a higher resolution 2" to 4" LCD: Then you could use CRT-projector lenses that are plentiful and go for around $10 on ebay. Or even $0 for three if you can find an old junked CRT projector sitting on the curb on garbage collection day! |
#2017 |
Projet ( UDIY ) BRASIL
- Ecran toshiba 10.5" - Kit HQI 150W 5.200 k - Fresnels F1 220 mm - Fresnels F2 320 mm - 2 ventiladores 12 v - Triplet de 320 mm - Matériaux principal de la Box MDF - Connectique de la Box : AV VGA TV - Distance de projection 2,70 m - Taille de projection : 1,30 x 1,180 m http://projetordiy.com.br/forum/view...p=26553#p26553 |
#2018 |
Hi All
I am unable to get MH with Ballast at my place, the dealer has offered few alternatives. 1. Philips Aluline Pro 37/56 mm Product Description • Low-voltage halogen burner in a lightweight, high-gloss anodised aluminium reflector giving a white halogen light Product Feature • Integrated protective front glass • Choice of clear or frosted glass • High-intensity beam with an extremely clearly defined beam shape (clear glass versions only) • Excellent color rendering Product Benefit • Excellent accent lighting effects due to reduced spill light (clear versions only) Application • Excellent light source for accent and general lighting in shops, home, restaurants, galleries, exhibitions and museums Rated Lamp Wattage: 35W Beam Angle : 6D Lumens Intensity: 18000 Rated Voltage : 6V Another Choice Philips MASTERColour CDM-R 35W/942 E27 PAR20L 10D Watt : 39W Voltage : 85 Color Tempeature : 4200 Chromaticity Coordinated : x - 371, y - 366 Luminous Intensity : 21500 Beam Angle - 7.5D, Spot Option3 Philips MASTERColour CDM-R 70W/942 E27 PAR20L 30D Watt : 73W Voltage : 88 Color Tempeature : 4200 Chromaticity Coordinated : x - 371, y - 366 Luminous Intensity : 13000 Beam Angle - 26D, Narrow Flood Please help me in taking a decision Regards Naidu |
#2019 |
hi everybody I have this projector
benq pe 5120 at projector central is wrote that it mount a p-vip lamp but in the projector box it needs a nsh lamp the problem is thet I've bought a vip lamp is there someone that can help me? are the vip and nsh compatible? thank you http://www.projectorcentral.com/BenQ-PE5120.htm |
#2020 |
The video sections have now been created. Threads will be moved to their relevant sections as time permits, and things nicened up a little.
http://www.diyaudio.com/forums/foru....php?forumid=12 |
| Page generated in 0.13986 seconds (75.92% PHP - 24.08% MySQL) with 11 queries |
