#1911 | |
Just to add to the thoughts though, i can get a frensels lens here that is actually manny frensels in the one sheet, from memory they are 1 inch across so maybe they would work to create a large evenly lit backlight. If i had the money sure id be in the testing too, but when i can buy a metal halide setup for way less , why bother lol, yeah yeah ok heat and life ect but still i wouldnt pay 2k for a light source. I got my light today btw and thanx, it got here in 1 peice. Trev |
#1912 | |
#1913 | |
Xenon would be nice but then we have the issue of heat, more so then metal halide unfortunatley, but yeah xenons are nice. Trev |
#1914 |
i was thinking of using a xenon for a while till i talked to my roomate. he is a theater projectionist so he took me up to the booth and we looked at the projectors. There is absolutly no way we could use even a smaller xenon bulb, 1) the heat is much much to high (and the fact that if you get hand oils on them they will explode
X |
#1915 |
I use the xenon bulbs in surgical illuminators at the hospital that I work at. Heat is a major problem. On the higher wattage ones, there is more heatsink in the bulb area than bulb. And one finger print on the quartz, and KABOOM!!
#1916 | |
Also if anyone interested. I found a chart of what o beam is what size at said feet. Nice to know how big beam of light is. I scaled it down to inches even. Mine is 5.6" FD for ENH. So beam smallest there. Then goes back up. Good spot for removing heat with my little setup.
Optics are a science...... Projection a ART! |
#1917 |
I really donīt understand what you mean ? I hope you or someone else can explain this.
Here is some exemple what the lumens output of some bulbs are: 50W 12V Halogen 4000h 930 lm 100W 12V Halogen 4000h 2400lm 250W 24V xenon-halogen 50h 10000lm 400W 36V xenon-halogen 50h 14500lm 150W HQI 12000h 12000lm 250W HQI 12000h 20000lm Sure you get a brighter beam with a reflector, but not more lumens. When you use a reflector the light beams concentrates in one direction and light what goes in one direction is measured in candels not lumen. If you put a 1000lm bulb in a reflector and then change it to a 20000lm bulb, which is brightest ? |
#1918 |
Who said we cant retrofit out a pro projector with a cdm-t bulb, i have and it works fine.
Trev |
#1919 |
Here is the old bulb, im going to drop it off of my balcony just to see how much of a bang they actually will make lol, the arc size on this old fellow is 6mm, and is metal halide.
Trev |
#1920 |
Is the beam wide enough to cover a LILLIPUT complety at a short distance.(8 or 9 inchs).The new comercial projector have a smaller hole for the lamp and you cant retrofit a cdm in it.
| Page generated in 0.14134 seconds (77.28% PHP - 22.72% MySQL) with 11 queries |
