#1881 |
Sorry, with refration I mean dispersion (rainbow effect).
#1882 |
Mathias, what about the blue spectrum? there is red green and blue to make up white light, the rainbow effects wont accur on a lcd, ive never seen this and about all u would see on a miss- matched light system is a blur, the rainbow effect could possibly be seen if the operating frequencty of the light is lower then the lcd's but even then with light combined already coming from each source combined into 1 u wont see this effect, the lcd filters this light with its own static colour filter. Dlp has this issue because the light beam is filterd into colour and operates at strict timming with a colour wheel, maybe u need to elaberate with this rainbow efect on a lcd because ive never seen it in my life.
Trev |
#1883 | |
#1884 | |
#1885 |
what do you think about this?
the first prism has a rainbow effect on the white light, the second reveals this effect, so one white light ray comes out. the black second light hits the second prism at a negative angle so this should be reflected and goes into the first light ray... so i have one out of two beams... based on this site and paint shop ![]() http://www.uni-leipzig.de/~stann/java/prisma.html |
#1886 |
Guys, im talking about using simple mirrored prisims here, its all u need, what prisims are u talking about? because u wont get a rainbow effect on a normal mirrored prisim.
Trev |
#1887 |
it's a normal prism, fully made out of glass...
but anyways, as i looked on my budget i decided to give the single 150W bulbed version a try, as i saw good results in the german diy forum where this guy claims to have a 70W MH bulb and got a picture bright enough on an acceptable size. May be the 150W will be enough to lighten a 15" tft; i'll give it try... P.S.: Did you receive my adress? |
#1888 |
heya slize ya i got it, im running out now to post it, btw i was talking about mirrored prisims, use those they are what we need for this aplication, the others will loose too much light.
Trev |
#1889 | |
Glassprism will not lose more light than a condensorlens, because a condensorlens is many small prisms. |
#1890 | |
Trev |
| Page generated in 0.12866 seconds (77.88% PHP - 22.12% MySQL) with 11 queries |
