Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 9th June 2002, 09:58 AM   #1
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
Default Post Finished Projectors Here!
I didn't see a thread for ppl to post their completed creations, so I am going to start one. Please, only post pics of your picture quality, and/or projector setup. Only if you are complete, or far along in the stage. It would be cool to see people's setups.
I'll start with mine:
LCD panel: NView Spectra C (modded, see pic)
OHP: Apollo Concept (4K lumen)
Screen: Da-Lite 60" glass bead
I totally dismantled the Spectra C, and mounted it directly to the stage of the OHP. Then, duct-tape around the edges, getting rid of like 70% of light loss. Then, with the space between the LCD and the stage, I used the fans to draw air from the space, and out the vent. works well, never and overhead issue and i've used it in 90F weather for 4 hours straight... (i have no A/C in my house). controller board is attached to back of projector in a make-shift cardboard box. this is just a temporary step.
Old 9th June 2002, 10:02 AM   #2
cowanrg's Avatar
and the actual picture....
(sorry for the small size, using sony handycam to caputre pictures, it can caputre in 0 light... picture is actually crisper)
Old 9th June 2002, 11:27 AM   #3
SushiMasterX's Avatar
Thumbs up Great Idea!
Please post resident panel resolution also.
See ya at the Symposium! he-he
Old 9th June 2002, 07:49 PM   #4
cowanrg's Avatar
Default Re: Great Idea!
NView Spectra C, 640x480. I will soon have better pics, once i get my digital camera working.
Old 11th June 2002, 05:18 AM   #5
Hello everyone. This is my first time here so be nice. Since finding this forum I've gotten really interested in building my own projector for big screen fun. I have a question for you, Cowanrg. I just won a Spectra C on ebay. It should be here in a couple of days. I've never used a lcd panel before. Does this panel have a video input or do I need an adapter? If I need an adapter I'd like to order one to be here when the panel arrives. And what kind of controller box system do you have? I already have the Overhead projector so I can't wait to see what my results look like.If they look half as nice as yours I'll be very happy. And I hope this is the appropriate place to ask.
Old 11th June 2002, 07:27 AM   #6
cowanrg's Avatar
well, for starters, this is totally the wrong place to ask.
but since i started typing, i might as well finish i guess.
the scectra c has its own inputs, which is the DB15 (computer monitor), AND if you get a newer spectra c, or just a spectra, it will have rca input as well. (some ppl may argue with me, but i know what im talking about... some do.)
as far as getting yours to look like mine, well, you need a high lumen projector AND removing it from casing and modifying it like i did helps tremendously. i do not have any other parts than the spectra c and my OHP. you dont need any controller boards, or any additional parts, UNLESS you plan on adding RCA functionality, (if it doesnt already support it). then you need an input box.
but, as im sure from your questions, you haven't yet thoroughly read the forums, i would suggest you do so, and you will find answers to the parts i left out.
Old 11th June 2002, 05:31 PM   #7
Default NView Spectra C
I have an NView Spectra C, and it has a VGA input, a composite (or RCA) input, and an s-video input. All work fine, though I'm sure VGA looks the best.
Old 11th June 2002, 07:00 PM   #8
Send a message via AIM to ldkaplan Send a message via Yahoo to ldkaplan
Default Question for cowanrg on resolution
Regarding the projected resolution, do you get the 'screen door' effect? I have an old Davis Powerbeam projector that my boss was getting rid of and I notice that a lot...the pixels are blown up so large they are annoying.
Also, are you using the same power supply for both the ohp and the display?
Old 11th June 2002, 07:17 PM   #9
cowanrg's Avatar
Default Re: Question for cowanrg on resolution
hum, as far as a screen door effect, not really. it depends on the source. if its a dvd, or high quality source, there isnt a screen door effect at all. but, if its a lower source, like an mpeg, or a divx or something, at times, with lower bitrate sources, you get a little pixelation. also, in very very low lighting scenes, there is blockiness. but that is really due to the source combined with low contrast... (commercial projectors have like 1000+:1 contrast ratios. mine, 100:1)
but you see the screen image, and thats at 60" (not diagonally, across). so, if you cant see the pixels there, they dont exist. there was 0 cleanup on that picture.
as far as power supply, OHP's use standard 120V from the wall. they have their own built in supplies for the light, etc... and the panel has an external transformer. i was going to wire them all together for 1 plug/switch, but i decided not to, since this is just my prototype, and ill be messing around more with it later.
but, its perfectly feasible to wire the transformer into the powersupply of the OHP, or vice versa, if you know what you are doing... or just use a powerstrip with a switch on it :-) that works too.
Old 11th June 2002, 09:44 PM   #10
Default vga input
cowanrg, on your spectra c, does it have a db15 input that says "Optional Monitor" on it? I have tried to hook up my computer to it, and it hasn't worked. Do i need the remote control in order to change inputs?
Finally finished - Long post. 5th element Multi-Way 5 16th May 2007 12:56 AM
Anyone on here make and cell finished projectors? jmolayal Swap Meet 4 18th March 2005 01:08 AM
P3A mono blocks finally finished (picture post) sobazz Solid State 12 31st August 2003 08:36 PM
Page generated in 0.11448 seconds (83.52% PHP - 16.48% MySQL) with 11 queries
