Hi all: Well after a few nights of work, I show you some pictures about my Lilli projet. Suggestions are welcome.
At this moment I still don't have the fresnel, the condenser and the front mirror. I bought them to Ace, and I'm waiting for these parts to arrive. But for testing purposes I started to make some parts of the projector. First picture: LCD mounting |
#2 |
face that will be hitted by the light path
#3 |
Box that will work as light tunnel. (not painted yet).
In that picture you can see the comercial reflector that I'll use. |
#4 |
In this picture you can see The ballast for the bulb (Osram HQI-TS/NDL 150 W). The LCD Panel, The mirror (common mirror while I wait for the FS to Arrive), The Box, and on the right in white a piece of the reflector.
#5 |
First running to test if all connections are good
#6 |
rear view
#7 |
Rear view 2.
#8 |
Front view, Here you can see part of the mirror. In this side will be the lens.
#9 |
hi gstuder nice job so far.
keep an eye on your wooden lightbox. it'll catch fire..... and i hope your lilli is still running facing you have laid the lil brown ribbon cable flat on your lcd-mount. that isn't good... maybe it still works, but me and few others did it that way @ 1st attempt and the harm was irreversible... |
#10 |
Hi I Eat Flowers:
So you suggest me to bend the brown cable? ¿at 90 degrees? ¿Can you post here a picture of you PJ showing that part. I'll really appreciate that. And if you add some explanation that will be perfect. The other night I was testing alltogether and the LCD turn black after 3 or four minutes. Has it ever happened to you? That for the answer. Gastón |
| CDPRO2 Group Project (open source project) | BrianGT | Digital Source | 147 | 8th August 2008 11:37 AM |
| My OLD Project....... cheap tube audio project!!! | tube-lover | Tubes / Valves | 4 | 8th May 2008 09:26 PM |
| Page generated in 0.10007 seconds (71.85% PHP - 28.15% MySQL) with 11 queries |
