Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 18th June 2004, 01:15 PM   #11
gstuder is offline gstuder  Argentina
I forgot to answer the question about the light box.
I bought an Spay Enamel for High Temp. (aluminium Color) and that support up to 1200 ºC. In the paint store they tell me that it aisle the heat to......
Tonigh I'll post the brand so you can tell me if anyone tried it before.
bye
Gastón
Old 18th June 2004, 01:45 PM   #12
hi gstuder,
find a pic in my signatures thread. yeah 90 degrees, that's what we are all doing with that little cable. do not bend it to often...it'll break. my advice : as long as your's working never touch it again.....
no, my panel didn't turn black at any time. i guess it's the heat.
in case you have no ir-filter use a glass to divide the lightbox from your panel. add blowers on your panel for cooling. the panel will work up to 45°Celsius.
cya.
ief
my own 7" project
http://diyaudio.com/forums/showthrea...504#post346504
Old 25th June 2004, 11:41 AM   #13
Pacho is offline Pacho  Argentina
Gaston:
Hola soy de Argentina, Santa Fe. Veo que vos tambien, donde vives?
Queria preguntarte donde compraste el lilliput, estoy buscando y no encuentro. La única forma es comprarlo en ebay, pero no estoy seguro cuanto me va a costar finalmente con envio, impuestos, seguro, iva etc.
Cuentame si quieres, donde lo compraste y si lo trajiste de afuera, cuanto te terminó costando la joda.
Gracias y saludos.
Old 25th June 2004, 07:00 PM   #14
Default NEWS
In the meantime I managed the get the proj. working and I improvised a Condenser with a magnifying Glass, but I don't have here in Argentina something to replace the fresnel while I wait yours.
I found here an acrylic magnifying glass, plane, that has the measures of a credit card, and that could work. But I think its very small. So I prefer to wait.
The projection is not too bright, and of course I have the center more brighter thant the corners, but its a good begining.
I tried to take some pictures but my digiftal camera only takes the center and the rest is as if doesn't exists. I'll try with a common camera.
I think that the coating of my lens take a lot of light. I tried to replace the lens with a common magnifying glass and the picture was amazing brightly. But it was very difficult to have an all focused picture...
Well that's all for now.
bye
Old 15th September 2004, 11:06 AM   #15
go77306 is offline go77306  Canada
any progress?
Old 25th October 2004, 07:57 PM   #16
Georgie is offline Georgie  Argentina
Send a message via MSN to Georgie
Default Is the 150W right?
Hi Gstuder! I am also from Argentina! Cordoba.
I am beggining with my projector. In my local Hardware store I could Only find a 150W MH lamp. 4200K Color temperature(I´ve read that it´s the appropriate color temp)
Is 150W enough?
The other problem is the LCD Screen. Are they easy to dissasemble and leaving just the lcd? I am planning to buy a 7" Pyramid LCD in a CarAudio Shop for U$s250 and I am afraid wether it will be easy strippable...
I appreciate any hints you can give me!
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 11:37 AM
My OLD Project....... cheap tube audio project!!! tube-lover Tubes / Valves 4 8th May 2008 09:26 PM
Page generated in 0.09699 seconds (76.09% PHP - 23.91% MySQL) with 11 queries
