Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 6th May 2002, 02:44 PM   #1
Default image inverter
Hi all
Is anybody aware of a DIY circuit that would allow a s-video signal fed to a LCD projector to be inverted (rotated 180deg) ie: to allow use of a lcd projector tht is not designed for ceiling mount to be flipped onto its back and mounted upside down on ceiling
many thanks in advance.
George a
george a
Old 8th May 2002, 11:21 PM   #2
haldor is offline haldor  United States
Low tech possibility, but how about a mirror?
Old 9th May 2002, 02:10 AM   #3
mrfeedback's Avatar
Hello george a,
This is not a good idea to mount a table top projector upside down because of ventilation/thermal issues.
Those arc lamps run damm hot, and the electronics are pretty cramped.
Regards, Eric.
Old 4th June 2002, 03:56 PM   #4
SushiMasterX's Avatar
Default Alas,
you may be able to physically turn the panel around inside, depending on the mount and any cable's being connected to it.
Have to open 'er up and see.
A front surface mirror placed in front of the projector. Projector faced the opposite way of your screen.
Old 23rd July 2002, 05:07 AM   #5
ap0the0sis's Avatar
Send a message via AIM to ap0the0sis
Default celing mount a tabletop projector
I was also thinking the same thing. I recently purchased a Sharp XG-E690U from ebay for $180.00. Its give a great picture for being a 220 ansi projector ( I figured I would spend more in making one than in buying this one). I can even watch it in day time with not much color wash-out, however it wasn't meant to be hung from the celing... which is where i would like to put it. I believe there should be a way, without mirrors to mount this thing on the celing.
I can't open it, already tried. There are some screws that would release the top cover of this projector and give me access but i cant reach them witha regular screwdriver.
I would really appreciate it if someone (technician or someone) would shine some light on this subject.
thanks,
ap0the0sis
Old 24th July 2002, 07:39 AM   #6
Find some off the shelf video editing equipment. Yes, their are schematics on how to construct one
OR
Use a computer to flip the image upside down. Its best to use a dual monitor video card. One output will be for computer related stuff. The second output will be the LCD or computer monitor that the image is flipped.
Note: An inverter will change all the colors to their opposite colors.
ePanorama.net is good start to find circuits
Old 24th July 2002, 09:18 PM   #7
Default Leave it the way it is.
You could always build some kind of holder or use a ceiling mount that was designed for a TV. That way you don't have to flip it upside down to be safe.
Like a shelf, ya know?
- Justin
Old 24th July 2002, 11:01 PM   #8
ap0the0sis's Avatar
Justinjay,
Please see the following pics: pretty much self explanatory...
if the projector is mounted to the roof or on a tv wall unit it will throw most of the projection image onto the ceiling since it is a table top projector. only way is to mount it and filp the image (some how)
I heard it is possible with a HTPC (Home theater PC) but i dont have one set up yet. so i need to find another method.
Old 24th July 2002, 11:02 PM   #9
ap0the0sis's Avatar
pic 2 (notice image hitting ceiling)
Old 24th July 2002, 11:11 PM   #10
ap0the0sis's Avatar
satisfactory....
ap0the0sis
CFL inverter Fob Power Supplies 9 5th July 2009 05:34 PM
12V DC to +/- 32V? Do I need to use 220 inverter? lagoausente Power Supplies 19 13th November 2006 04:22 AM
Show of hands for the Montreal Sound and Image Show (Le Festival Son & Image) alvaius Everything Else 2 28th January 2003 05:48 PM
Page generated in 0.10002 seconds (79.71% PHP - 20.29% MySQL) with 11 queries
