Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 25th July 2002, 12:33 AM   #11
Default ???
I thought the light would be spread evenly and not tipped tword one direction.
The projector's I've delt with do not throw the image higher than itself and you have to put books undernieth it to make the image high up enough.
I don't understand why you have a problem. maybe your projector is designed differently.
If the image is partially projected onto the cieling just tilt it down a bit so it shines on your screen.
Then you might complain about keystone problems, but wouldn't you get keystone anyway if the projector was mounted upside down?
- Justin
Old 25th July 2002, 04:30 AM   #12
ap0the0sis's Avatar
Send a message via AIM to ap0the0sis
yeah, this projector is different i guess. i guess when they design a projector to be table top... thats all they want it to be.
this projector shoots most of the image up.. like shown in the pics. i guess its so that you dont have to set it up on books/blocks/boxes.
i have to worry about keystone because this projector can only correct it by 10%. if i get to much keystone then the image will be all @#$% up and i would like a decent projection. i guess i will try to flip the lcd over or set-up a HTPC to see if it works.
ap0the0sis
Old 25th July 2002, 01:45 PM   #13
You got a svga projector for 180$. Was anything wrong with it?
I'm really shocked.....wish i saw that
Old 25th July 2002, 06:17 PM   #14
ap0the0sis's Avatar
it works great actually. bulb works fine, its a little on the white side but i believe it still has a good amount of life left. ( i just finished watching "Stephen Kings, The shinning", 6 hours long with no problems. it has low lumens but i am really happy with it since i have a totally dark room, i can also watch it with the lights dimed a bit.
there a guy on ebay selling the same one for $499.00 but not a single soul has placed a bid on it.
ap0the0sis
Old 25th July 2002, 06:23 PM   #15
Thats much better than me.......i've got the following to fix before i can play with my projectors
Proxima DP5100 I paid 170 for it without a bulb
Infocus LP220 paid 70 without a bulb or lens......this one is 800*600 but might be harder to get to work finding a lens.
If only I could control my ebay impulses.
Old 25th July 2002, 07:29 PM   #16
ap0the0sis's Avatar
lol, im an ebay-oholic. i cant keep away from it. i mean there is so much to buy and so little to buy it with. sheeeesh
i would probably spend all my "lotto winnings" on ebay
i dont know if it'll do you much good but here is the link to the site that i found my projector malp from for $160 instead of $300+ like in all other sites
http://www.vanltg.com/vantageorder/lcd/lcd_index.html
Old 29th July 2002, 07:08 PM   #17
I tried emailing those guys a few times and never got a response from them. so I gave up on them.
Old 30th July 2002, 04:34 AM   #18
ap0the0sis's Avatar
i've been having the same problem. maybe it's better to just get them on the phone and ask. I will try tomorrow and let you know what happens.
ap0the0sis
Old 31st July 2002, 08:21 PM   #19
ap0the0sis's Avatar
I just tried flipping over the LCD inside my projector and it didn't work out. The image projected was really washed out. Almost completely white.
I guess the light has to go through the LCD through the front of it. I noticed that on one side of the LCD it has a silver looking film and on the other it is a little darker. Polarizer maybe?
So now I have another idea. If I can locate a piece of flat 40 pin wire I can rotate the LCD without flipping it over. The wire it comes with is really short so it has to be replace with a longer piece.
#'s on the wire are as follow:
E66085 AWM 2896 80C VW-1 BANDO - s
I need a 1 foot piece. Anyone know where to get it? Or get something similar?
Thanks,
ap0the0sis
Old 5th August 2002, 11:56 AM   #20
Default image invert help sony
Firstly, thanks to all for your commnts on the image inverter. I still haven't got anywhere though and I'm sure others will have the same problem-to clarify..
I have a lcd projector that is not designed for inversion (sony vpl-cs4) which I wish to ceiling mount. I cannot find anything that specifically tells me how to use a htpc or software or graphics card or DIY option to do it- can anybody help?--
Interestingly the sonY vpl-hs1 is a projector designed for home theatre and supposedly cannot be inverted (ceiling mounted).
How ever it actually can if you access the right service codes in the setup. dealer showed me how....
thanks again to all
george a
CFL inverter Fob Power Supplies 9 5th July 2009 05:34 PM
12V DC to +/- 32V? Do I need to use 220 inverter? lagoausente Power Supplies 19 13th November 2006 04:22 AM
Show of hands for the Montreal Sound and Image Show (Le Festival Son & Image) alvaius Everything Else 2 28th January 2003 05:48 PM
Page generated in 0.09992 seconds (80.34% PHP - 19.66% MySQL) with 11 queries
