Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 28th October 2005, 12:25 AM   #41
Send a message via MSN to mindless_fool
i got a viewsonic pj501...i took it apart and figured out a few things..just need some help from you guys...i turn it on..not much happens cause it wants a bulb...so i need to figure out how to trick it..i think i found the cable that goes from the mainboard to the ballast but i dont know how to short it...its got 3 brown wires and a yellow one
here is a pic:
another question is in the front coming out of the mainboard are two wires connected to a black thingy what is it?
Old 31st July 2007, 01:05 AM   #42
Default Tricking projetor to accept bulb
I found a sharp xv-zw99u tv projector in the dumpster. It was thrown out because it need a new lamp. I saw why after pricing them! I built a new holagen bulb for it with 300w 120 v bulb. I know they get hot so I will keep an eye on that. Heres my problem, the lite works for one second and something clicks and the light goes out, and if I keep the machine on, the lite will relite for 1 second about every 30 seconds. I read your emails to Kahurt on other site, and he has the same unit I have. I need to know how to trick the machine to accept my homemade bulb. I think I have the four wire unit. I was wondering if you figured out how to trick the four wire unit? Your help would be greatly appreciated. Thaks Matt
Old 1st August 2007, 03:42 PM   #43
ywh is offline ywh
Send a message via MSN to ywh
Hi !
I have this short arc MH lamp , and it is JYS , I am selling it
http://www.diyaudio.com/forums/showt...35#post1268635
it is cheap, only $40 each, you need intall bulb into you old reflector only, without any change, don't need change ballast....
what is the words on the ballast?
Give up the UHP and HQI lamp now! Take a look at our LED projector!!http://www.diyaudio.com/forums/diy-p...e-theater.html
Old 27th March 2008, 11:51 AM   #44
I have an old Sharpvision XV-H37U and am just wondering if you ever figured out a way to trick on of these. Not sure which bulb option I will use at this point but want to know if anyone else has had any success that they may share with me.
Any and all information will be greatly appreciated.
Old 7th September 2008, 01:19 AM   #45
here is a pic:
I knows this is really old but hey if you are still around This is what you have to do. jump the 2 middle brown wires and thats all there is to it. You probably have a switch where the bulb goes so you will have to make sure that switch is closed. I guess this can help other people to.
sharp XV-100 projector aadb Vendor's Bazaar 0 7th June 2008 04:00 AM
Page generated in 0.11843 seconds (54.39% PHP - 45.61% MySQL) with 11 queries
