| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hello All,
I am new to this so if my question is really dumb, my apologies! I just bought a used 3M MP8650 LCD projector. It powers up well, and projects a blue screen. When connected to my PC ( Dell Dimension /NVidea card/XP)via VGA cable, the screen remains blank. Changing the input setting does not change. Interestingly, when the PC is booting up the projector projects the PC screen very well (ie..the Windows logo while booting)..however, the moment the login screen comes on..the orohected image goes back to blue. My best suspicions are that either I dont have a driver..or the projector is incompatible with XP. Could connecting the PC via s-video cable help (my video card has TV out)? Has anyone faced a similar problem? Can anyone point me the right direction? Thanking you all very much in advanced! eklf |
#2 |
what is the resolution that your panel will do? XP will only go down to 800*600 and if your panel will only do 640*480 you might not get an inmage of the desktop. It may be thr refresh rate also.
The light that burns twice as bright burns half as long! |
#3 |
Does it work in safe mode (to get into safe mode, pus F8 when the computer is loading up keep on pressing it untill a menu starts up, select safe mode)
.have you downloaded the latest drivers from nvidea? |
#4 |
hi,
the projector is 800x600 native. it will scale but to stay safe the projector its self should be set to 800x600. the go in to your computer and change the monitor setting for a 800x600 desktop and a safe refresh of 60 cycles and see what happens. it sounds like your projector if working fine. |
#5 |
It sounds like your resolution is set to high on the windows box. Windows XP will go down to 640x480 if you need to test the projector.
Right click on your desktop and go to properties, go to settings, and click on the advanced tab across the top. Now a window will open that has a tab for adapter. Click on adapter and down at the bottom there will be a list all modes button. Click on it and you can set XP to any resolution the card will support. Personally I would start a 640x480 60hz and if that works I would work my way up to 800x600 60hz. If it does not work then you know the problem is elsewhere. I do beleive from the way it sounds though that the resolution is set to high in windows. just my .02 Chris
__________________________ Current System Specs Bell and Howell Projector using a 600 watt dys bulb Nview Spectra C Dedicated DVD player HTPC Computer For more information check out www.chrisrowland.com |
#6 |
Hi guys,
Yup...you were absolutely right. The problem was the resolution. I changed the resolution to 800 x 600, and it worked like a charm! *whew*..For a moment I thought I had completely sunk my dough ($300 for a used one). Thanks a lot for all your help and advice!! eklf |
| Thread Tools | |
| Is there a 5 inch computer screen? | Jonasa | Digital Source | 7 | 3rd November 2006 06:48 PM |
| Page generated in 0.15097690 seconds (81.27% PHP - 18.73% MySQL) with 10 queries |
