diy projector from the Philippines - Page 77 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 3rd December 2011, 07:54 PM   #761
Duplicated the ist build. Box is alittle smaller and improved keystone by lens shifting.
Old 7th December 2011, 12:51 AM   #762
Dear hertzblaster sir,
can you tell me whether a small LCD with HDMI or DVI available?.
Also can you post the ebay link to AUO 10.1 inch B101EW02 or similar LCDs. My search reveals links only to panels.
Old 8th December 2011, 06:49 AM   #763
The controller is programmed for me by the big controller supplier in China which specializes in big LCD TV controller. They don't entertain small orders.
Old 8th December 2011, 07:29 PM   #764
Dear Hertz sir.
I am a true fan of diy projector idea.and of course yours :--).
what I am getting locally.220/330 fresnel(310mmX310mm),345 triplet,15.6 benqG61hdal lcd,400w bulb.now problem is 310mm wont cover full 15.6 lcd(350mm lenghwise),and if I use 4:3 mode of the lcd to use it with 310mm fresnel,there will be picture distortion.and I live in india,there is a lot of problem with customs,taxes etc if I bring lcd+controller from other places.can you suggest me something by which I can use this lense with this lcd.
another question.of course it is a proven fact from your builds that led will give better picture,but led and led driver is not available locally.do you have led+drivers?
also suggest me that this 15.6 benqG61hdal,regarding FFC issue and stripping,other things(picture quality) I can compromis.
thank you very much sir for your help.
new student prosenjit from india
Old 10th December 2011, 06:01 AM   #765
dear prosenjit
U can order 400 x 320mm fresnel from optolife dot com for ur LCD.they are most trusted and u can get all diy projector parts from them .There is no customs problem and i have received my parts just yesterday.
regards
Srinivasan
Old 10th December 2011, 06:44 AM   #766
400x320mm are mostly defective. There is a problem in center groove and the outer groove. You get a brown dot at the center bec of 220mm fresnel. And bec of defects in outer grrove, you ll get considerably low brightness at the sides.
I ordered samples from different fresnel suppliers popularly known in this site. .
The 395x395mm is the best quality fresnel for 15-16 inch lcd.
Old 10th December 2011, 07:52 AM   #767
Oops ,i received it.. ok let me try this and order from 3dlens dot com in future.
Old 15th December 2011, 06:50 AM   #768
keimjay is offline keimjay  India
hertz sir
i did my pj with 220/330/310 and with benq 15inch monitor. absolutely no problem, watched 2 movies, and the next day when i tried to finalise my design and close the box, i have damaged the LCD. there is some vertical lines in two three places, any idea to correct it
Old 15th December 2011, 09:12 AM   #769
Sorry can't help w/ lcd problem.
Old 18th December 2011, 07:15 PM   #770
still using 126w led and B101EW05
Copyright 1999-2017 diyAudio
