#691 |
No, not me
Tescorp was having a similar issue with a 400W double ended lamp in one of his builds that it shows a hotspot in the middle, and I remembered that you had solved it. But I also am just curious to remember the solution By the way, the builds you've been doing with the HSD lamps have been incredible. I've also seen similar 575w versions of the same lamp at the same price, but running those lamps are need extreme cooling |
#692 |
#693 |
#694 |
#695 |
#696 |
#697 |
#698 |
good day mr. herts,im gio from cebu i saw your projects about the diy projector.im planning to buy an 32" lcd in our room,but when i saw your projects id rather to build my own diy projector,you mentioned that you hav a spare of 7'' lcd monitor set with the lenses,is it okay with you that ill refund you oon that..hehehee by the way i saw lots of furoms about this diy but iyour project is best..by the way heres my no. 09279222232 thanks more power..
#699 |
Wow, you have been busy. You have some excellant results. is this with just the 250W single ended bulb? I checked their site and I will have to get a few to test with.
Awesome results on the projector you built for the restaurant. |
#700 |
I was trying to find out info on the bulb from that link but the people there are so clueless about the products they sell, do you need a ballast to fire the 250W bulb? looks like you could hook it to a dimmer switch to knock down the voltage. I read that to get rid of your hotspot you turned down the voltage 5 volts which to me sounds like you have a dimmer switch or some way to adjust the voltage to the bulb.
Awesome results!! Thanks in advance |
| Page generated in 0.12097 seconds (73.23% PHP - 26.77% MySQL) with 11 queries |
