#521 | |
For an electronically controlled ballast, we can not determine what voltage and current is sinking through it .... For example an OP amp that has source voltage of +15 and -15V ..... thats not a 30V drop accross it, but rather the Power supply that the op amp draws from, so therefor with active controlled device its hard to assume the voltage loss across it is the source line voltage minus the output lamp voltage. the latter type a coil ballast, is nothing more than a transformer really ..... in which case Pin=Pout ..... (with a very minimal power loss in the core) For example I use a coil ballast in my PJ. its hooked to 120V... therefor 400VA = 120V * I .... rework the equation .... the current solves to be 3.33A draw .... this is the current going into the ballast .... the ballast then uses that current to step UP the voltage.... Voltage increases and current decreases ... but 400VA maintains ... Ive measured my output voltage to be 275V ... And my output current from the ballast is calculated as .... 400VA = 275 * I ... where I is 1.45A ..... There is a minimal power loss in the transformer itself, due to the mere physics of it ... My coil ballast is a multi-tap .. and it has a 240V input as well .... If I used that, the input (primary side of the transformer) would be ... 400VA = 240V * I .... where I solves to be 1.6667A of current. The output side (Secondary of transformer) would be the same ..... In BOTH cases .... the transformer will have similar losses ..... cause you cant really look at current alone, you have to look at power .... The transformer has specific windings .. that equate to a turns ratio .... the turns ratio on the 120V input is .... 275V/120V = a turn ratio of 2.29. If it were to reduce the input voltage from 120V to 100V .... , then the output voltage would not be 275V, but rather approximately 229V ... and then we would no longer have 400VA. |
#522 | ||
Back to the school days from me. Ahh! Sweet memories of the 80's.
Here is the link that may help you and others to understand about types of hid electromagnetic ballast that you think about. http://www.hubbell-ltg.com/products/...t_circuits.pdf Quote:
This is what i believe it should be. Be careful when you say minimal power loss in the core. The hid lamp operates like a short circuit ( negative resistance). Meaning the ballast windings resistance is the one that will limit the current. Power loss is not minimal.We know that the ballast feels hot. Ballast is consuming power. HID balast is more carefully designed unlike ordinary transformer. Ordinary transformer is not operated normally under full load unlike the HID ballast and it is not thermally protected. Quote:
When I designed and diy a transformer, power loss is a big consideration. If I want a certain power delivered to the load at certain voltage and right current, I want a wire that is accurately size otherwise voltage drop is higher in the transformer ( low voltage regulation) delivering high current ( high power loss) that may damage the connected load and overheat the transformer. I thought about designing and diy my ballast but no time for now, maybe after retirement. |
#523 | |
Trev
"Every technique can be used in a great many ways, but mastering it, thats what realy counts." |
#524 | |
#525 |
in a decent transformer, there will be minimal power loss compared to the power on the output .... for example my ballast is 400w .... I have no where near the margin of power lost in the core of the transformer.
The type of load will effect its loss, and you can calculate the Rcore if given the Zcore and vice versa. to determine this loss under different loads. but with a normal set-up, from a half decent ballast should only lose a fraction of the power compared to the power its outputting. none the less, regardless if the power loss is minimal, or exceptional in both cases of condition 1 vrs condition 2 similar power will be dissapated in the transformer. A transformer is a linear device, meaning that its output/loss/input are all correlated with a simple linear equation. Likewise Power is correlated with a simple linear equation (I * V) ... therefor when one element rises, the other element falls ... but the same work is done .... |
#526 |
After a 2 second search:
http://www.uppco.com/business/eba_12.asp A bit about ballast materials: http://www.fcs.arcelor.com/prd_web/D00_EN.html Trev
#527 | |
Assuming i have 250 watt Hqi- tsd Rated voltage : 100v ( voltage across the lamp) Rated current : 3 amperes We need to deliver 250w of power to the lamp but can be achieved in different ways. 1. Use a ansi recommended 250w ballast to give 100v running at 3 amperes equivalent to 300va. 2. Use any ballast to give 250w to the lamp, say 60v at 5 amperes is also equivalent to 300va. I experienced the 2nd case when i wrongfully bought a 250w metal vapor ballast. My iimage is dim in this case. I have to overdrve the this ballast just to get a decent image. Always look at the rated current and voltage of the lamp so that you will know what ballast to buy. Ballast are lamp specific . Don't assume that same power rating of the ballast under the 2 conditions will give the same performance. The 2nd condition will perfrom miserably and can damage your bulb because of high current ( overheating). If you know how to use a mutlimeter, (Safely!), you can check it now. If we have the same bulb, the voltage across the bulb should be 100v. If its lower, you will have to use a variable voltage regulator to increase the voltage, otherwise the lamp is dim and you will see severe green tint in your projected image. If its higher than 100v, i guess 10% overvoltage is ok but may not be safe enough.. Expect a very bright image under this condition. This is true only for electromagnetic ballast. |
#528 | |
#529 |
This is an awesome thread.....and very impressive picture quality Hertz!!!
#530 | |
BTW, my lcd has just celebrated its first year under severe punishment from me. lol! Its still working flawslessly. I guess a commercial projector could have not withstand the torture for a year from me. Imagine watching at an average of 3-6 hours a day five days a week. Turning on, turning off atleast more than twice for every use. And a lot of times experiencing overheating of lcd ( big brown blob at the center) because of carelessness. I believe its ok now for this lcd to die on me anytime since it has already provided me with lots of fun and goodtime before.
| Page generated in 0.17072 seconds (84.90% PHP - 15.10% MySQL) with 11 queries |
