#501 | |
#502 | |
but I was unaware of that being a standard, in every house plug your your hair dryer into the wall system .... |
#503 |
Yep, this is the reason why electricians usually install the breakers in a balanced number between the left and right columns in a breaker box, e.g for six breakers it would be two colums of three instead of one column of six. This balances the load between the different phases wired to the box (typically one phase supplies each column).
#504 | |
Well Scuba, Whatever you paid for that sterling education, you clearly didn't pay enough. You say an INCREDIBLE amount without actually answering the question. In fact, you say just enough to indicate that you got the facts COMPLETELY wrong. That aside, I am VERY impressed with your algebra... Hertz: Thanks for your help. I am happy to risk a ballast collapsing within a matter of days.
#505 |
hertzblaster,
I just browsed through and must say - your pics of your image are incredible! |
#506 |
Scubasteve2365,
Sorry if i sound offending in my reply but i don't meant it that way. Thank you for reminding me how to get the power factor mathematically.. Its just that i thought we need to test it in a real world with a meter to get the realistic result. We will need given data in order to come up with our computation. All i want to say to goemon run the ballast under correct operating condition to get the best result. Running the ballast undervoltage will give you bad result. Its true that the lamp will draw more current from the ballast but the lamp brightness will suffer. I have a variable power supply and i had an idea already how bright my lamp will be at different voltage and current supplied to the ballast and the lamp. A wattmeter could help us out better in determining power (watts) consumed by the lamp. ( 250 watts Hqi-tsd is rated to run at 100v at 3amp.) BTW, I have 3 Hqi-bulbs and you will be surprised that each operate at different voltage using the same ballast. The one that operates at higher voltage is brighter than the others. The one that operates at higher current at lower voltage is dimmer. At least base on my subjective experiment.. I've been reading the tutorial from Advance transformer about how to get the best from HID ballast and i guess being an electrical engineer like us has an edge to easily grasp the knowledge and can easily share and explain it to the others the simplest way possible. Regards, Hert |
#507 | |
The high current will cause the ballast to heat up, not the power it delivers to the lamp. example using the same ballast Ist condition : 100 volts x 2 amp = 200va 2nd condition ; 50 volts x 4 amp = 200va Condition 2 will run hotter because of bigger power consumed by the ballast. Ballast temperature will be different under this 2 operating condition. |
#508 | |
That is assuming that in both conditions the circutis are stable... If the 2nd condition is TOO much current for the circuit, as to where all the internal devices are running hot, and reaching their threshold ... then the 2nd condition will run alot hotter ... but not for long, before something releases the magic smoke .... and it no longer works .... I also think alot of this will matter depending on if your using an electronic ballast, or an old coil ballast. Im using a coil ballast, and the thing spits out a consistant 275V-300V with an open load (No Bulb) ... I havnt really measured with the bulb in ... but im certain that different bulbs will draw different brightness (even if they are supposed to be the same) |
#509 | |
but Im curious to know what FACTS, I have wrong .... better yet completly wrong?? Please Educate me where my Professors have failed to do so ..... LOL ... |
#510 | |
| Page generated in 0.13632 seconds (81.53% PHP - 18.47% MySQL) with 11 queries |
