Go Back   Home > Forums > > > >
diy projector from the Philippines
Old 4th August 2004, 04:25 PM   #361
hertzblaster is offline hertzblaster  Philippines
If you want to see more of the images from my projector to compare with yours, i had them in slideshow. I had just updated it and it can be seen here.
Again, please use internet explorer browser only. Will not work with opera. i am not sure with netscape.
http://www.hertzblaster.statichost.co.uk/myresults.htm
Old 4th August 2004, 09:49 PM   #362
Tiarb is offline Tiarb  Finland
Hi!
Herzblaster, as you have been taking lots of result pictures, I'd be really happy if you'd also take some images like mentioned in the http://www.diyaudio.com/forums/showt...726&highlight= thread and post them on that thread, that would be wonderful, thanks
HB
my stuff is at http://tweaknmod-av.tk
Old 5th August 2004, 12:46 AM   #363
Tiarb,
Thanks for comments. I would try it sometimes. You know i feel lazy using my pc as video source because i have to set it up whenever i want to use it and its kinda messy in my small house and just happy and satisfied with the result using composite input of dvd player. I will just put a disc and lie down in the couch then with a remote, boom! i have a nice image. Of course with pc image is better because i can use 800x600 resolution instead of 640x240 with the dvd player.
Hertz
Old 9th August 2004, 02:01 PM   #364
Found a good use for a cheap magnifying lens. My experience is shared here
http://hertzblaster.proboards12.com/...cgi?board=lens
Old 10th August 2004, 07:49 PM   #365
ace3000_1 is offline ace3000_1  Australia
ace3000_1's Avatar
Send a message via Yahoo to ace3000_1
heya hertz, you been reading my thread about duel condensers? same thing, you dont move your light at all back, the first condenser has to be a short focal and the socond has to be a long focal, you only move the 2 condensers to get the image right or the image will go dim, having 2 condensers makes a diff eh? lol
Trev
Old 11th August 2004, 01:13 PM   #366
Yes trev, i read your thread about your dual lens set-up the only difference we had is, since my condenser lens has about 6 inch focal, i have to use 2 then later add the magnifying lens. It really made the difference.
Had tried dual fresnel lens set-up but had not yet made any success.
Thanks a lot.
Old 11th August 2004, 04:36 PM   #367
BTW watched mona lisa smile. Here is a nice shot of my fav J.roberts
Old 23rd August 2004, 11:21 PM   #368
dave123 is offline dave123
Hi Hertz, can you post any computer games screen shots?
Old 24th August 2004, 03:43 PM   #369
Sure no problem, i will just post it in my site.
BTW, need some comments from you guys about ballast. I am currently using ballast for mercury vapor lamp.
As far as I know, mercury vapor lamps uses ballast with ANSI rating of H37. After reading some more. I found out that i should be using a ANSI rating of M80 ballast for double ened bulb.
Will changing my ballast to M80 will further improve the lumen output of my lamp?
Anybody's insights will be appreciated.
Here is a link for beginners training for HID ballast. You must register to open the training session.
http://ult.digiscript.com/index.cfm
Old 24th August 2004, 04:34 PM   #370
ace3000_1's Avatar
Try the life and saftey of the bulb or you, recomended ballasts are recomended by manufactures for a reason.
SAFTEY WARNING!!!!!!
Use only apropite ballasts and lamps in acordance to manufactures recomendations, failing to do so will result in a serious fire - personal injury risk!!!
Trev
diy projector from the PhilippinesHide this!Advertise here!
