Anyone wanna try either one out:
8,4" Model number: NL10276BC16-01 Display method: SFT, normally black Pixel number: 1024 x 768 Display size: 170.9 (H) x 127.9 (V) mm Luminance: 350 cd/m2 [1] Contrast ratio: 500:1 Display color: max 16,777,216 Viewing angle: Up/Down ± 85° ; Right/Left ± 85° [2] Response time (ton): 25 ms Outline dimension: 200.0 (H) x 152.0 (V) x 12.0 (D) mm Power Supply: 3.3V Power consumption: 10 W Input signal: 1-chip LVDS interface (8 bit / 6 bit) 6,3" Model number: NL10276BC12-02 Display method: TN, normally white Pixel number: 1024 x 768 Display size: 129.024 (H) x 96.768 (V) mm Luminance: 250 cd/m2 [2] Contrast ratio: 300 : 1 Display color: 16,194,277 colors Viewing angle: Up 45°/Down 60°, Right/Left ± 60° [2] Response time (ton): 6 ms Outline dimension: 178.8 (H) x 126.8 (V) x 12.0 max(D) mm Power Supply: 3.3 V [4] Power consumption: 5.2 W Input signal: LVDS 1-port interface [Digital RGB (8-bit for each RGB) Dot clock, DE] Both need an controlled though ![]() http://www.ee.nec.de/products/displa...76BC16_01.html http://www.ee.nec.de/products/displa...76BC12_02.html Also found a place where u could possibly get one: http://www.review-displays.co.uk/ |
| Full range flat arrays (big or small) ? | norman bates | Full Range | 7 | 15th April 2009 11:51 AM |
| support for small full range | Artmaster | Full Range | 8 | 20th November 2006 08:59 AM |
| Help selecting a small Full Range | mimir | Full Range | 9 | 31st August 2005 05:41 AM |
| Full Thiele-Small Papers Now Online | richie00boy | Multi-Way | 6 | 11th January 2005 12:06 PM |
| Driving small full range ribbons | setmenu | Multi-Way | 6 | 10th January 2003 11:38 AM |
| Page generated in 0.07314 seconds (75.89% PHP - 24.11% MySQL) with 10 queries |
