Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 14th February 2004, 06:19 PM   #1
Account Disabled
Default Meeting@Mall For Panel Where2TestPanel
Hi i'm buying an lcd panel off some guy and we're meeting at a mall is there a quick way i could test the lcd panel to work? how do i power it up and know if its working anyways? thanks!
Old 14th February 2004, 09:34 PM   #2
uvodee's Avatar
Default it is
nearly impossible....
you will never be close enough to a high lumen output lamp to check the thing out, and if you would have that luck, you would also need to have a source like dvd or so, and if the panel only has vga or svga IN than you might as well take your computer with you or a cheesebox....
I would make sure that you get soem kind of warranty or bring him to your place or do whatever so you are able to negotiate yourselve out of it when the thing does not work, be carefull also for dead pixels!!! hard to see at first glance and without a source.
J-P
Old 14th February 2004, 11:22 PM   #3
Account Disabled
how would i locate dead pixles
Old 15th February 2004, 02:36 AM   #4
If it's a panel for an overhead projector, the most you could do without getting hassled by security guards is hook it up to a portable device (laptop w/vga out, portable dvd player with video out, etc) and then hold the panel to the light while it's powered up. Every mall I've been to had a food court with wall outlets around, I'm sure they wouldn't mind too much if you plugged it in.
Dead pixels will appear as dots that don't move or change color on the panel. You probably won't be able to tell without a powerful light behind it, but if you saw a big cluster of dead pixels, don't take it.
Old 16th February 2004, 03:29 AM   #5
Account Disabled
i went and bought it works fine =) how come my panel sharp qa-1150 allows me to set it on 32bit high colour mode? it's supposed to have 185,000 colours only.
Old 16th February 2004, 04:50 AM   #6
uvodee's Avatar
Default i can't help you on that one
but if the setting allows you 32 bit mode that does not mean your panel operates like that, it could just as well mean that it supports it but still only reflects the 185k C.
J-P
Atlant DIY speakers Meeting-8/8/09 bobhowell Multi-Way 0 22nd July 2009 12:17 AM
DIY meeting in Belgium ? jim Tubes / Valves 3 2nd December 2004 01:08 PM
DIY meeting in Belgium ? jim Multi-Way 0 2nd December 2004 07:32 AM
DIY meeting in Belgium. jim Everything Else 6 1st December 2004 08:07 PM
DIY meeting in Göteborg Sweden peranders Everything Else 0 27th May 2003 09:52 AM
Page generated in 0.07761 seconds (73.74% PHP - 26.26% MySQL) with 10 queries
