Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 14th February 2004, 03:37 PM   #1
Default My Project, Ups and Downs
Hey,
Here is a thread to show you my work so far. Basically I was running a 400W MH 1 year ago with sharp 1650. Then I moved up to 250HQI and sharp 1650 (looked quite good). Then I sold the sharp 1650 and purchased the Lilliput 7" (same time Ace did). BUT while I was constructing, static electricty screwed the lcd over So... here are pics of what i was doing, Im thinking of some alternatives for cheaper LCDS because I will primarly be using this for video, NOT VGA.
Here is a pic of my first experiment with the 250 MH and a reflector.
Old 14th February 2004, 03:38 PM   #2
Here is a picture of the Holder for the reflector I made.
Old 14th February 2004, 03:39 PM   #3
Here is a pic of the Reflector in the light box.
Old 14th February 2004, 03:41 PM   #4
Here is a pic of the double ended MH installed
Old 14th February 2004, 03:42 PM   #5
Here would be a pic of the UV/IR filter and holder, this will sit a few mm's over the bulb and the only light passing through it will be to the Condensor.
Old 14th February 2004, 03:44 PM   #6
Now here is where the condensor holder will sit, I've made the 4 legs for it to sit upon.
Old 14th February 2004, 03:45 PM   #7
Here is the UV/IR Filter and Condensor holder complete ready to be put into light box.
Old 14th February 2004, 03:46 PM   #8
Now here is a pic of the setup in the light box.
Old 14th February 2004, 03:48 PM   #9
Now the messy and somewhat freaky part began. I bought a magnetic ballast for the bulb because Electrical was unavailable to me. I created the ballast its own box, and you can see that I put the 2 Outputs, I made it like that so the light box isn't always attached to ballast, so I can unplug it whenever I need to remove one or the other.
Old 14th February 2004, 03:56 PM   #10
Here is a pic of ballast box and light box connected. They look quite big in the pic, but in real life they aren't that big, I should have put something beside them so you can compare size.
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 11:37 AM
My OLD Project....... cheap tube audio project!!! tube-lover Tubes / Valves 4 8th May 2008 09:26 PM
Fixed Bias: the ups and downs alexmoose Tubes / Valves 26 11th July 2006 11:34 PM
My first project, cool project. sorinsistem Solid State 3 19th January 2006 05:08 PM
Page generated in 0.09010 seconds (81.33% PHP - 18.67% MySQL) with 11 queries
