Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 13th February 2004, 02:06 AM   #1
whisper is offline whisper  Canada
Default Sending image through top of projector
I'm sure someone has thought of this, but I am unable to find anything;
Would it be possible to just remove the mirror entirely from your OHP and put a hole in the top, allowing the image to pass directly through? I have included a picture to help describe what I mean.
If it ain't broke, break it so you can fix it.
Old 13th February 2004, 05:01 AM   #2
dracul is offline dracul  Brazil
makes sense to me. But what would you gain with this? The mirror is First surface is it not?
Old 13th February 2004, 07:55 PM   #3
Actually I was hoping to remove the mirror, as this would just be in the way. The reason being; I find that in my household setup, a longer projector, rather than a taller one, would be better. One thing I could see being a problem with this, is the amount of excess light coming from the base, that would pass by the lense. Of course, you could put a simple box around the light that is showing, and just make sure to cool it.
Old 14th February 2004, 03:03 AM   #4
Send a message via AIM to partyharty Send a message via MSN to partyharty Send a message via Yahoo to partyharty
The only problem you may have a mirror usually flips the image as well.
Old 14th February 2004, 04:23 AM   #5
Dnt32 is offline Dnt32  United States
Send a message via Yahoo to Dnt32
Default Without Mirror
The only difference is that the image would be flipped. This set up would work for rear projection or front projection with an image flipping software.
I believe YWH uses this set up but I could be wrong.
I could be wrong about this but you would actually gain some light output, maybe not noticable.
It wouldnt be anydifferent than taking the guts from the projector and putting it in a box.
As far as light leakage it shouldnt be any different with or w/o the mirror.
"Tie two birds together, though they have four wings they cannot fly"
Old 14th February 2004, 04:54 AM   #6
The easiest way to flip the image is to physically flip over the LCD panel.
Isaac Kuo
Page generated in 0.07853 seconds (71.23% PHP - 28.77% MySQL) with 11 queries
