Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Closed Thread
Thread Tools
Old 19th January 2002, 09:01 AM   #501
Myren is offline Myren
Send a message via ICQ to Myren Send a message via AIM to Myren
hey all
thought i'd check in. i got my own setup running using the LCD matrix from a 15 inch flat panel (viewsonic vg150). its powered by a bell and howell 388a, which is a big metal box with one of <a href="http://www.donsbulbs.com/b/i/d/dys.dyv.bhc.html">these</a> bulbs stuffed in it. works pretty damned well. the bulb just burnt out after a particularly long use, and i've already got 12 replacements en route.
i've been working madly on the screen for the system. right now its <i>still</i> just a couple sheets haning down. i've got a huge sheet in the back yard, drenched in double good plus matte goddness ultra bright white paint. spent half a gallon on that one sheet.
it should make for a far better viewscreen. its impressive as is, already capable of being run with a bit of ambient lighting plus a black light and still looking sharp. i'm amazed how much light the thing puts out. but the new screen should be nothing short of a revolution.
i've got serious plans for version 2.0. i need a bigger fresnel though, something big enough so i could mount one of those 1280 x 1024 17 inch lcd panels to it. as is, i'm loosing some of the screenspace of the 1024 x 768 15 inch lcd i'm using, and thats just gotta change. i'd like to use some sort of zoom setup, but i'm not totally confident in my raytracing abilities.
also, the cooling right now needs some work. i'm thinking of taking out two of the standard fans and adding a second squirrel cage fan. with a decent mount job, it'd look a lot better than it does, plus it'd be a helluva lot quieter. just a silent whir in the background.
this is a totally different realm that we've talked about, does anyone know what it'd take to be able to make a small in home buisness out of making these for fun and profit? i couldnt just rip apart viewsonic monitors though (and use them in my prodcut), which is unfortunate (considering how easy it was to do). i still think theres hope of bringing a slightly larger slightly more powerful way cheaper projector to a small market.
waiting for bulbs to arrive. hopefully i can spend this time productively, before i get wrapped up in playing more video games.
Matt
Old 19th January 2002, 10:42 AM   #502
Send a message via Yahoo to John_in_Az
Wink Matt
Matt,
Making these for profit kinda breaks the spirit of this whole thing. However, I'm sure my friends will want one, and I don't mind charging a SMALL fee to build em one.
Anyway I was thinking of building a few for my family once I got the optics and lighting right. I'm still looking for the right LCD to use too.
Has anyone tried the portable Playstation LCD's ?
I know it was mentioned a few times during this thread, not sure if anyone posted the results yet. They sell NEW for $100.00 here at Toys R Us. The have the AV inputs so all that would be needed is to remove the backing and driver board. I'm also able to resolder if the driver board is in the way.
I think I can get the optics right once I find a suitable LCD. STill waiting for my bid on ebay to finish
BTW..Matt, what are you using for your projection lense ? I think that may have something to do with your screen loss.
If you dont get the lcd to center exactly on the lense you WILL loose some of the picture.
Well ill post my results once I get my lcd.
Later
Old 19th January 2002, 07:05 PM   #503
Hello again...Even though thoose laptop lcd screens are realy cheap, the bigger lcds (8"->) are cheaper anyway, so going for a bit bigger screen than the <-3" doesn't sound bad. I was also searching for some bright and good looking lamps. Many of thoose Osram lamps seems like a good idea. And the costs are around $30, I've checked it with a lokal dealer. At that prize, running 9000 lumens+ (GX6 lamp, but it all depends of what lamp is selected) it shouldn't be a problem to get thoose big pictures bright enough...or what do you think? By the way, check this LUMEN monster out! http://catalog.myosram.com/srvc/z_my...00000000000000
if that link doesn't work, go to the product guide www.osram.com and search for E4050300283104. Using this kind of lumens at 63amps should realy bring things bright 500.000 LUMENS!! This baby must cost a fortune...
Old 19th January 2002, 07:32 PM   #504
Matt,
I am also looking for a large fresnel; C&H Sales have a 33-1/4" x 24-1/2" for $89 (stock item #OL9008 which is way too expensive for me.
http://www.candhsales.com
For the screen check this board, http://www.avsforum.com/avs-vb/showt...threadid=93780 . They are having a ball with some low cost plastic material that is going to **** off some big business moguls.
Old 19th January 2002, 10:25 PM   #505
Default project pics
I now have some pics of my projector so far on the web at "www.geocities.com/zark5150".
Old 20th January 2002, 04:18 AM   #506
Default Re: project pics
pretty good, did you order another LCD yet?
Old 20th January 2002, 08:58 AM   #507
Default CHAT ROOM NOW OPEN !
Hey guys,
I just set up a chat room on IRC (mIRC) on dalnet.
If anyone is interested, join the #DIY-LCD-PROJECTOR chat room
using a IRC client. The most common type is mIRC, which can be downloaded at http://www.mirc.com
If you dont know what IRC is, or need help setting up your irc, leave me a msg here, or shoot me an email.
Let's get together and share ideas in a more interactive environment.
I also plan to set up an FSERV to allow us to share pics, video etc. Without the need for webspace.
So come on in, and lets get started. My nick there is Truluv. Drop me a msg if your interested in contributing to the channel.
Leave your forum name if it is diffrent then the nick you will be using.
Thanks,
John
Old 20th January 2002, 09:03 AM   #508
by commercial i pretty much meant build them for friends for a small fee. spread the low cost projection goodness.
i cant stress enough how nice it is using a nice big LCD. the lcd is actually a bit bigger than the projection screen, so not all of its used, but a bigger fresnel will fix that. i have the lcd a lego brick width away from the projection surface, so focusing is actually pretty close to how focusing would go normally.
the huge c&h fresnel looks really tempting. you'd most likely end up cutting some of it off but $89 isnt that much too pay for a fresnel. better than the uber-ripoff of edmun scientific which wants to charge like $300. just think of how nice a system you'd ahve with a whole 18.1 inch 1600x1200 LCD matrix in it. smooth as silk.
oh, and one thing to consider is that the closer you can put the bulb to the fresnel (can be done with ?greater? focal length?) and still have the optics work out, the more light your collecting simply by inverse square law. of course, i think you also loose optical quality. i'm going to guess projectors are probably some place around the sweet spot, and run with it from there.
i'd like to setup my basement to produce $1000 projectors running 1600x1200 using the DYS/DYV/BHC bulbs. I'm thinking of using a custom metal frame with squirrel cage fans for cooling (hunting for good source online for squirrel cages). it'd be kinda nice to setup a block that i could mass-weld frames on for future use, and then just assemble everything. and on the plus side, all you'd have to do is throw in a $250 15 inch 1024 x 768 matrix instead of a $900 18.1 inch 1600x1200 resolution matrix to drop the costs, with only the loss in resolution for a price.
version 2.0 is gonna have the optical systems mounted on a one dimensional slide system with automated stepper motors controlling the positioning. i'd like to figure out how zoom lenses work and to get this rangefinding system working, which would let me pretty much enter a screen size in software and have the automated microcontroller adjust the optics to relative perfection. no clue how the zoom lenses work though. sigh. might just have to deal with autofocus. need to find a good book and work on a zoom lense setup though.
unfortunately, i left the docs for my current automation hardware at my dorm. i havent started the firmware for version 2.0 - and cant really start it - until i get back to my dorm next saturday.
trying to get my pictures developed and scanned. will have photos soon. might have to setup a geocities account. *shiver*
oh, and watch your heat levels everyone. the lcd matrix's usually are only rated for operating temps of 104 F, with storage tempts climbing into 140 F range.
Old 20th January 2002, 09:08 AM   #509
oh, yeah.
we got snow, and it snowed all over the screen i had just painted in the back yard. its sitting in the living room on a giant canvas right now. not sure what my plans are right now, its gotta move by tomorrow night or inventing privledges might get cut off for a bit.
the thing was looking great though. its just a pretty thick sheet painted in about half a gallon of extra-flat extra-bright acrylic paint. was going to be one of three sheets comprising the screen, which will be carpet taped to the wall.
i have a backup projector i'm using now. its pretty weak, nothing compared to the 600 watt monster i've been enjoying so much.
Old 20th January 2002, 09:27 AM   #510
Thumbs up Myren....
Dude you online ???
Come to dalnet on irc... #DIY-LCD-Projector.
Sinse your up so early, err late ? LOL
Closed Thread
Thread Tools
Page generated in 0.31240010 seconds (81.71% PHP - 18.29% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
