Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Closed Thread
Old 31st October 2001, 02:20 PM   #181
dwalls32, how strong is your flashlight that you was using for the test? Is the idea of LEDs still possible?
Old 31st October 2001, 02:55 PM   #182
It's a 1,000,000 candle flood light. It is bright, but only in the center of the beam. Outside of that, it gets too dark to cut through the panel. I need a "flat" light...
Old 31st October 2001, 08:49 PM   #183
Oh ic.. do you think it's possible to use car headlights? There are white lights that is extremely bright.
Old 31st October 2001, 09:04 PM   #184
Well, this is where I could use some electronics help. Vince, I bought the same powers upply you did for leds. It's 12v 47 watt. I bought a big halogen car high beam. It's 12 volt, 50 watt. I hooked it up to the power supply and can get light, but it's not bright at all. I'm sure I don't know how to hook it up correctly. Anyone?
Old 31st October 2001, 09:32 PM   #185
Helix is offline Helix  United Kingdom
Helix's Avatar
light conversions :
1 flame = 43.05564 meter candles
1 foot candle = 10.76391 meter candles
1 lux = 1 meter candles
1 foot candle=0.25 flame
Old 1st November 2001, 01:31 AM   #186
but then, how does it convert to ANSI Lumens?
About your power supply, I think it just doesn't have enough power. Why don't you try using the computer's power supply, the yellow wire is 12V but I don't k now how much current it has.
Old 1st November 2001, 05:43 AM   #187
Great work dwalls32, now we know it really works!
btw, I just read Popular Mechanics, Oct 2001 issued,
page 117, an ad about flashlight using 4 led's.
They said its beam can be seen from a mile away.
maybe this type of led could work for our project.
Myren,
there was someone who did the same way (ohp and lcd monitor):
http://www.avsforum.com/avs-vb/showt...&highlight=OHP
to cooling down lcd panel,
I saw product demo before, about clear laminated sheet (V-KOOL ?),
They laminate a piece of glass and beamed with very hot lamp
(it'll fry your hand in second), but behind the glass you can't
feel any heat!
dwalls32,
you can't use that power supply, its defenetely not enough power.
rule of thumb you should double the power needed.
why don't you use 12 volt car battery just for trying, before you find the right power supply. (cheap OHP trafo can be use for it)
Don't forget using reflector behind the lamp, its really important to beamed the light.
maybe worth to try 150 watt Xenon bulb type, it's real white light.
Old 1st November 2001, 06:18 AM   #188
Thanks Gunawan. I'll look for that glass heat reducer.
Old 1st November 2001, 08:11 AM   #189
Default Some People who have made video projectors
http://www.audiovisualizers.com/madlab/lcd_proj.htm
This person has made a video projector and peoples email how also have made them.
Old 1st November 2001, 03:11 PM   #190
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
I know we said that floods are not the best solution, but here's something for testing.
http://www.allelectronics.com/cgi-bi...-50&type=store
Closed Thread
Page generated in 0.13763 seconds (66.38% PHP - 33.62% MySQL) with 11 queries
