| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
#11 |
I think hes using a second mirror from to reflect the image onto the screen.
Jimbo |
#12 |
Location: Schwarzwald, Stuttgart "near" the Octoberfest
... you have to be careful with inconsiderate pre-assumptions! Read the following explanation carefully completely and you won't say that again!
Freebie and the whole german users have understood my setup instead of you! But no problem: For you two from the fast-firing unit (first firing, then maybe thinking 'bout the consequences) , I'll show and explain you details. Exclusive for both of you, I will repeat it in simple structured and clear english to help you understand my technical setup (as it is completely and detailed explained in ebay germany (german language, Sorry!)): I'm using a very bright 10.000 Ansi Lumens OHP (Liesegang trainer spezial, 6.000 Kelvin) It projects the Image against a mirror which itself mirrors the image and reflects it to the screen backward to the OHP. The reason for this unconventional setup is: My TFT-display has a anti-reflexive coating on the front. The light provided by the OHP doesn't pass the Display effectively if the Display is positioned face-up on the OHP. I made some test runs at the beginning and had a huge spot and a washed out image with faced-up-display. This was the start: Afterwards, I recognized that turning the display round and putting it on the OHP face down, the result was great. No spot! Bright and crystal-clear picture with great colors. But what happens If you put a Display on a OHP this way moltenrock (face down)????? Guess what? Stay a while and think about it on your own! >>>>Right - The projected picture is projected mirrored on the screen if you project it directly on the screen, which means: the projected picture-information which should usually be placed on the left is shown on the right side and inverse (projected picture is flipped horizontally or mirrored on the screen). So I had to find a solution to get the picture back in its usual position. Software solutions for flipping the projected picture back in its correct horizontal position were out of reach and I recognized, that a simple and usual mirror will do it! Thats the easy explanation for this unconventional setup! A mirror flips the mirrored picture back in its usual horizontal position! But as you can see as follows, it works great! look at my illustrated setup with mirror! If you want I can add much more pictures from different angles. The photographing-position I took for the ebay auction which you posted, was taken behind -and lower- to the mirror. Photographed in direction to the screen. Instead of freebie You didn't mention, that in all of my ebay auctions there is another photo plus a crystal-clear explanation for all of my setup-details! Additional: If you want to look in the german DIY forum. There is a detailed explained Setup with al the components and their explanation/illustration. see: http://web102.sun-15.de/forum/phpBB2...ight=rallafatz[B] |
#13 |
Hi guys,
A little help for you to translate other websites. Just enter the URL here and select language to language: http://www.freetranslation.com/web.htm There may be better/other services, but this one is probably good enough. |
#14 |
...once more...
The OHP with Display on it (face down), the ventilator (cooler fan), the white barrel with the additional two 7 cm PC-fans inside. As you can see in my scheme, the way of the light-beam is reflected by two mirrors: -First of all the mirror of my OHP -and afterwards: the mirror which reflects the picture to the screen in 4x2 meters. Higher screen-size would be no problem, but our attic-wall is too small for bigger things. Maybe I should try in summer (open air-cinema, maybe on our neighbours house-wall). I guess 10 meters without significant loss of light and picture quality must be possible. I'll post It if I've done. Maybe I'm getting a little insane by the size, but aren't we all a little crazy?! |
#15 |
rallafatz i apologize for being inconsiderate in posting so quick before realizing you had an explanation in german describing how your setup was designed please forgive me for my stupidity
i am truly sorry |
#16 |
i thought the same thing as cruser at first but before jumping to conclusions i looked closer and found the mirror but im still wondering how an xga res lcd could provide such a good picture at such a large size? I dont see any screendoor at all!
Now im not sure if my math is correct but it seems that in inches its at least 160 inches diagonal, which is pretty big, at least bigger than most projectors around here, and i rounded down on decimals so image size could actually be bigger, so i dont see how its xga or wxga and that big and not have a little screendoor thats visible in the pics!
IF YOU WANT SOMETHING DONE RIGHT, DO-IT-YOURSELF!!! |
#17 |
This it how it looks from half a meter distance:
Believe Me: When you're viewing films with a distance of about 5 Meters to the screen, you don't see any pixelized-effect or something like that. The TFT has a contrast-ratio of 300:1, resolution native 1024 x 768 Pixels, response time of about 30 ms (absolutely liquid Video-Projection even in very fast scenes taken from Top Gun (which is great, if the Aircraft flying across your attic and the earth is shaking!!!!). additional information to my resolution: because of a not enlengthable flat-flex-cable, I have little part of the circuit card in the picture. But that doesn't matter in 16:9 mode. I easily drag the Window of my DVD-player to the upper end of the screen and no circuit card in sight. In 4:3-mode I do the same. native resolution of the 4:3-box might be abot 800x600 Picels then. But If you think about the native resolution of 4:3, then its almost always PAL-Resolution (720x540 Pixels or somewhat). So You see: the resolution in case of 4:3-viewing is still acceptable. I recently saw some Music clips from Axel Rudi Pell and Within Temptation in 4:3 and it was great in spite of reduced resolution in 4:3 mode. And be honest: Who of you is building a DIY-beamer for watching 4:3?! I guess 16:9 is the main employment for your setup, isn't it? See more of my pictures in full size under (klick on thumbnails there to enjoy the pics in full magnificence): http://people.freenet.de/rallafatz/B...humbnails.html |
#18 |
well i just turned my lcd around backwards and i dont see any difference at all, like me u too had the same problem with the dot in the middle, that can be fixed and its your optics that are out not the lcd's coating.
Trev |
#19 |
just out of couriosity do u have a pic of the lamp your using? and what type is it? how manny lumens ect.....
Trev |
#20 |
This are the specifications of my used bulp/lamp (used in a usual "Liesegang, Model: trainer Spezial":
http://www.dj-corner.de/manuals/manu...hmp575WSEd.pdf |
| Thread Tools | |
| schematic variation and sim results of Pass "X" series US pat 5376899 | tiefbassuebertr | Pass Labs | 13 | 30th July 2009 09:33 PM |
| Aleph 4 - Simulation Results from "Circuitmaker" | tiefbassuebertr | Pass Labs | 0 | 18th July 2009 12:53 AM |
| Results of waveguide "measurements" not so good ... | paulspencer | Multi-Way | 6 | 31st August 2006 03:04 AM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 31 | 18th June 2002 04:49 PM |
| Page generated in 0.25052094 seconds (87.74% PHP - 12.26% MySQL) with 11 queries |
