Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 11th May 2004, 06:36 PM   #41
ace3000_1's Avatar
Send a message via Yahoo to ace3000_1
Heya Bob, it works fine without it, check to make sure your fcc cable is in properly.
Trev
Old 11th May 2004, 09:13 PM   #42
bobharry's Avatar
Ok thanks, it must of been the ffc cable that was connecting when I pushed the left corner of the lcd, after that I took it apart, took the cables out and put them back in, which fixed it, so now I'm not too scared of stripping it again at least.
Thanks again,
Bob
Old 12th May 2004, 09:23 PM   #43
bobharry's Avatar
Ok, this time I am not mad or anything like that, just very sad, so sad that it is making me very relaxed lol. Well I tried stripping it again and when I was finished I got the weird error screen, so I tried putting it back together and I still go the error screen, after around 2 hours of trying to make it go, I have gone from bad to worse, now all I get is a plain white screen. I don't know how it could be the ffc because I have been putting it in very carefully over and over, so I think it might be static. If you think it is static, where did you get your lilliput repaired ace? I just want to get the darned thing working, then I might sell it, I'm just too scared of screwing it up again.
Old 13th May 2004, 04:03 AM   #44
ace3000_1's Avatar
hehehehe i havnt goten any lilliput repared yet, i hear that you can buy the small controller card for it but its not cheap, you can get them from japan at some recycled lcd place and thats only if its from static, the way i found the fault on mikes with was with mine, swoping the parts around to see what was dead. make sure u got the cables in the right way round and if you took the red fcc cable out its hard to get back in so it might not be all the way in, the white one takes alot to break.
Trev
Old 13th May 2004, 07:43 AM   #45
bobharry's Avatar
Well I didn't even know the red one could be taken out, so maybe I pulled it out by accident, I'll have to check.
Thanks again,
Bob
Btw, I'm sure you said earlier in this thread that you had a lilliput sent for repairs. Ok, just read it again, you didn't have it sent for repairs then, it just needed repairs.
Old 22nd May 2004, 01:45 AM   #46
on the subject of lilliputs in cars - check out mine
Old 24th October 2005, 08:57 PM   #47
cougarz is offline cougarz
Default LIILIPUT FLAT RIBBON CABLE
Hello everybody.
I made my mistake!! I broke the ribbon cable connecting the lcd to the main card in lilliput 7" touschscreen monitor. I looked so far but i can't find it!! Can you help me? Some of you know where i can still find this cable?
Thank you
Paolo (italy)
Thread Tools
Page generated in 0.17597294 seconds (75.32% PHP - 24.68% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
