Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 15th January 2004, 09:02 PM   #1
dracul is offline dracul  Brazil
Default Multiple projectors to increase resolution
Can someone explain how the nvidia multiple desktop method allows me to output 2 xga images to 2 different projectors?
Do I not need 2 identical outputs on my nvidia video card?
My geforce4 440mx 64mb only has one output of everything.
Lets say we are talking about presenting a 2:35 anamorphic movie from a dvd rom. We want one desktop to show the left side of the full widescreen image but it should fit xga aspect ratio or close. And the other desktop to show the right half of the movie. Each of the desktops now have to output to each projector. Correct?
1900x1200 All the way baby!!!
Old 15th January 2004, 09:05 PM   #2
Also, what cpu do I need to playback 2 xga video souces?
Old 15th January 2004, 09:40 PM   #3
if it says it has the ability to output to 2 monitors in extended desktop form then it has 2 outputs (2 vga outputs), and really all you need is a 1 gigahertz pc for dvds, but if your going to have high defintion video on it then you need a 3 gigahertz pc, becuz reading high def and reading a dvd and upscaling it to high def are 2 totally different things! and beleive it or not, if you have 2 3:4 screens side by side its wider than 2.40:1 which is as far as i know as wide as they make dvds, so you would have black bars on the sides no matter what dvd your watching unless you zoom to cut off the sides or stretch it for crappy image distortion!
IF YOU WANT SOMETHING DONE RIGHT, DO-IT-YOURSELF!!!
Old 16th January 2004, 12:16 AM   #4
What if you simply built 2 panels into one projector instead of 2 projectors.
It seems like you would have an easier time getting a consistent picture if they were in the same PJ using the same light source.
I think with 2 projectors ud have a hard time ever getting rid of a line down the middle because of slightly diff brighness etc. But if they shared the same light source they might look perfect across the whole image.
The optics setup would be interesting for this idea.
Heh you could actually use a 1000 watt MH and it wouldn't be overkill.
It might be difficult to bring the two halves together in one projector though...
Any ideas out there?
Old 16th January 2004, 12:30 AM   #5
ya ud need a huge @$$ fresnel too
Old 16th January 2004, 01:26 AM   #6
cruser's Avatar
you wouldnt need a huge fresnel just 2 regular ones heres aquick drawing of something i had in mind with 2 1600X1024 lcd's
now this isint to scale or anything its just an idea
but you could never move the pj once its set up
Old 16th January 2004, 01:33 AM   #7
i think they meant to have the lcds side by side, but ya ive thought of that before, but having two projectors or one with them side by side does tend to leave you with better options for movability and keystoning and basically not just a permanent thing!
Old 16th January 2004, 04:51 AM   #8
Ya I was thinking more along the lines of side by side, with one objective lens, although the optics would be challenging this way...
Old 16th January 2004, 04:54 AM   #9
One thing that would be kickass about this setup is that you could let a buddy plug his pc into half and you could game side by side on equally ginormous screens...
The more I think about this the more appealing it sounds....
damnit 2 LCD's would be pricey though...
Old 16th January 2004, 06:02 AM   #10
This is what I was thinking needs to happen with a 2.35 movie.
Multiple subwoofer/multiple amp question boogs Subwoofers 5 13th November 2007 05:36 AM
Multiple Drivers to Increase Efficiency markkanof Multi-Way 43 11th June 2003 11:00 AM
Page generated in 0.14333 seconds (63.68% PHP - 36.32% MySQL) with 11 queries
