#71 | |
#72 | |
Supposedly there was a small improvement in black levels between the cloth alone and the painted material... that made me want to go out and buy it right away, cause I’m the "king of perfection." I didn't cause my wife is the "queen of not spending money when the current blackout cloth is working just fine." So I’ve only used the cloth for my box. Now I’m looking at a larger screen size than I can stretch from fabric and thinking about buying some of the goo myself. Let me know if you like it. Paul www.paulbillett.com |
#73 |
15" LG Flatron 575LE - Works, needs 20pin FFC extension, quite easy to unassemble except some connectors were so tight that they would begin to break when i tried to separate them, solution: I cut the metal with metal scissors to get the lcd out of the frame.
Yet Another DIY Projector http://www.mydiyprojector.blogspot.com/ |
#74 |
I use three pieces of large white foam board from staples for $17. It makes a 108" wide screen. You could hardly see the split between the boards. But actually my wall paint works very well for the top and bottom on full screen because I could hardly tell where the edges of my boards are.
#75 |
please delete or move my previous comment, i was tired and exited about my ffc extension
#76 |
My screen is a PVC product that sign writers (does anyone actually still write signs?) stick the laser cut letters to. It comes in 2400mm x 1200mm x 3mm for less than $100.00...
I think it reflects and awesome image... Mark
CIH Explained |
#77 |
I need a (approximently...) 7' by 9' screen. My diagonal is 120" and all I have set up is a couple of 1"x3" studs with a tarp under, and a bed sheet on top.... its sucks.
any suggestions? I dont want to spend $75+ but I do not want to loose any screen size at all. im used to the massive screen. I guess I could sew 2 blackout clothes together but i think the seem would show way too much. thanks. |
#78 |
Hey, I found a really good material for use as a screen. It's blue styrofoam thats typically used as an insulator. It comes in sheets of 4' x 8' If you want anything more than 4' tall, what I've done is cut two pieces to 5' x 4' and line them next to each other and use packing tape to connect them. THe result is a really nice picture and always goona be flat. The picture just as good as the blackout cloth I have ued in the past.
#79 |
i just bought a dlp projector and am going to have friday movie nights at my house i found that the white vinyl shower curtain heavy duty works great i put 4 of them together and have a screen of 10'x13' for $6.00 each used white duck tape to put together
glad to be back in cali |
#80 | |
6/12/06: Redesigning everything, finally putting in the Ushio S400DD. |
| Page generated in 0.11242 seconds (72.87% PHP - 27.13% MySQL) with 11 queries |
