Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 21st November 2003, 03:13 PM   #1
LOOie is offline LOOie  Australia
Talking CMV1515 working with OHP (lots of pics)
hi, all
first... BIG THANKS TO ALL the guys on this forum for help and information, without which I would not have achieved these results. Of which, I'm reasonably happy considering this is my first attempt.
i guess the best way to show appreciation here is to throw some information and experience back into the mix for everyone. i'll keep posting infomation about my setup here in this thread (with pics too )
here we go..
LIGHT SOURCE: A+K Scholar 400 (400w halogen EVD)
LCD PANEL: CMV1515 flat panel monitor
SCREEN: my dirty white bedroom wall
I agonised for ages over the choice between the BENQ 581s/567s and CMV1515. In the end, the CMV1515 won out because opinions on the forums seem to sway towards it as better overall (though not suited for OHP, which was what I was planning!).
I thought I'd take a chance anyway, it seem to be better suited for the primary task I wanted it for.. games
See this post for more info..
CMV1515 vs BenQ 581s
Old 21st November 2003, 03:20 PM   #2
and so it begins..
Old 21st November 2003, 03:25 PM   #3
it took me about 2 hours to get this stage.
i was trying to be really, really careful. i've never pulled apart something like this before.. considering it was brand new and less than a day old
i would be really upset, if i screwed it up at ths stage.
Old 21st November 2003, 03:43 PM   #4
font cover off finally..
TIP: if you have digital camera, take LOTS of pictures of every step of the disassembly process.
reason being... you may want to put back it together again so day in the distant future. i took a picture pretty much everytime a i removed something.
these was especially important for the CMV1515. for some reason, these things are a lot more complicated than my PC (which i regularily tear apart for some reason or other).
It seems to have a fair number of screws of different (close) sizes which its going to very annoying if you dont know where they go.
There was a fair amount of metal shielding too, which I'm removing (and basically discarding) hmm.. i guess there was prolly a good reason for it.. i wonder just how much EM and other wonderful types of radiation these things give out. i'm imagining all those x-rays being pushed out by that big white cathode base
Old 21st November 2003, 03:46 PM   #5
ok.. its done, stripped naked. very sexah...
note: do not lay it out like this.. i'm an idiot.
Old 21st November 2003, 03:52 PM   #6
this is why..
you can see all those delicate high density black flat cables being stressed, pulled and bent at 90 degrees along the top the LCD. only takes one to tear a little then the panel is an expensive paper weight. luckily they were tough enough for time i was playing with it here but why take the chance?
note the small yellow cable forcing this configuration. it was about this time when i realised that i might have a problem with the flat OHP tray setup i was planning.. erghhh..
Old 21st November 2003, 03:58 PM   #7
here's that agravating little cable.. its prolly big enough to extend but i'm cringing at the thought of actually cutting it.
Old 21st November 2003, 04:02 PM   #8
here it is mounted on the metal tray holder thing that was orignally holding the LCD to the cathode base. As Brainchild suggested in another thread, it siliconed the LCD to it to protect it and the cables. I didn't use as much as he did though, just enough to secure the corners in case i had to take it apart again.
Old 21st November 2003, 04:10 PM   #9
Mr.Kh is offline Mr.Kh  Canada
Looks awesome, I just got my Samsung152T apart yesterday, and damn the panels look sexy :P But your FFC looks way nicer than mine eek :P Yeah I am really worried about cutting the FFC I know I can extend it with my pro-skills at soldering, but ... EEK!
Nice work and pics!
Old 21st November 2003, 04:13 PM   #10
my light source.. 400 watts of halogen goodness. its ******* bright and hot enough to barbeque on the stage (ok, i'm exaggerating a little... but it's a really hot light)
it has color temperature adjustments (means just moving the light bulb up and down inside the projector casing) and a turbo bright mode (i think it just switches the spare lamp on at the same time as the primary one... like it wasnt hot enough already. thats 2 x 400w halogen lights inside that small space)
TIP: do not look directly into the lens when the projector is on, you will be blinded for about 5 minutes and there will be a big purple/red spot in your vision for the next hour or so
Aurasound, Scanspeak Revelator, Seas Excel, Peerless XLS 8 (LOTS of pics) thadman Swap Meet 50 7th August 2008 06:18 AM
New Member with lots of pics.. Ludapower Introductions 34 31st December 2007 10:44 PM
Page generated in 0.10969 seconds (83.13% PHP - 16.87% MySQL) with 11 queries
