Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 23rd November 2003, 02:29 PM   #51
LOOie is offline LOOie  Australia
here is the inside, lifting the LCD..
note: i'm going to redo this frame now that i know what works. its a bit ugly and an electrical hazzard.
Old 23rd November 2003, 02:51 PM   #52
cost?
hmmm.. this is how much i've spent in Australian dollars so far.
1. 400w halogen OHP from e-bay. $165AUD
2. brand new CMV1515 $495AUD
3. 2 x 12" fresnel lens $80USD(inc shipping)
4. clear polycarbonate sheet (from hardware store)1m x 1.5m $40AUD
5. wood.. free left over from something I found.
6. 2 x 10cm PC fans, free from several old PCs I have.
7. AT power supply for fans, $5AUD from PC markets.
overall.. i have most of the features of a mid-range 1024x768 commerical projector at about less than half the price of an entry 800x600 commerical projector so i'm reasonably happy..
Old 3rd December 2003, 08:56 PM   #53
does plexiglass (or polycarbonate as you call it...... the same?) work as an uv-filter?
Old 4th December 2003, 12:08 AM   #54
cruser's Avatar
LOOie very nice results job well done!!! nice to see people exparament to find what works best for their setups, and post their findings you are a credit to this fourm keep up the good work
Old 5th December 2003, 12:01 AM   #55
hassler is offline hassler  Australia
Hi Looie,
Good to see your setup is working so well.
I don't want to start the split vs non split fresnel debate in this thread, however I did find the image to be significantly sharper when both fresnels were placed before the LCD.
I know you had trouble trying to get the whole LCD Shown on your screen because of the PCB. Did you try flipping the LCD so that the light enters from what originally was the front of the screen?
My setup is as follows,
yellow = 6mm Low e glass (very transparent)
blue = fresnel
pink = LCD
this setup allows me to place the LCD very close to the top fresnel and I hardly lose any of my screen area. The amount of glass I have between the LCD and the light also stops the LCD from heating up.
File Type: png setup.png (878 Bytes, 1113 views)
Old 10th December 2003, 05:14 AM   #56
Blue_aerox,
The local hardware store had 2 kinds of clear plastic sheets, clear acrylic and clear polycarbonate. They are huge, about 1m x 1.5m and is used for plastic windows for houses. the polycarbonate was a little bit more expensive but also had a UV reflective coating on one side(according to the manufacturer's label) which the acrylic did not have. You'll need to check this first.
I'm not sure what Plexiglass is exactly.. my guess is that it is the same as acrylic?
cruser,
thanks.. i'm only following your good example i hope this will encourage more people here to do the same.
hassler,
yeah, the PCB was a pain but i found that this current setup works best for me.
i can seen pretty much the whole screen except a bit of the corners cut off but that doesnt bother me that much, my wall isnt big enough so that i could fit the whole screen on it anyway.
i think my setup a little different from yours as i'm using a projector setup, i.e. the OHP has a mirror at the top lens housing. i guess i could flip it but i will need another mirror.
what is 6mm Low e glass and where can you get it? the polycarbonate works very well but i wonder if glass will be better at stopping the heat.
Old 10th December 2003, 06:08 AM   #57
Low e glass is made to absorb as little light as possible, much less than regular glass.
I got mine from Pilkington glass (they have stores nation wide), You can get 3mm sheets if you want, they only had 6mm in stock when I went to see them.
Old 2nd February 2004, 06:25 PM   #58
AirPlus is offline AirPlus  Germany
Default CMV 1515
Hi Looie, Brainchild
me and a few other guys from Germany bought that CMV 1515 display you were using for your projector. We saw your great results and now the 1515 is almost the reference for 15" projectors here, as these screens really rock.
Unfortunately no one has finished his projector here as we are just in the process of disassembling the displays.
Basicly we are very happy about the displays and with the results so far.
I were just wondering whether you solved the problem of that short ribbon cable in the right corner of the bottom of your tfts already and if might know a supplier, who sells lager ones.
Kind Regards
Old 2nd February 2004, 07:02 PM   #59
Hi AirPlus, I'm using my CMV in an enclosure which doesn't necessitate lenghtening the cable. LOOie came up with some arrangement for his OHP route.
DIY Video Projector Guide: http://lumenlab.com/forums
Old 2nd February 2004, 07:13 PM   #60
ace3000_1's Avatar
Send a message via Yahoo to ace3000_1
brainchild im on yahoo can u jump on for a min plzz bud?
Trev
Aurasound, Scanspeak Revelator, Seas Excel, Peerless XLS 8 (LOTS of pics) thadman Swap Meet 50 7th August 2008 06:18 AM
New Member with lots of pics.. Ludapower Introductions 34 31st December 2007 10:44 PM
Page generated in 0.11049 seconds (81.57% PHP - 18.43% MySQL) with 11 queries
