Sharp XG-MB70X DIY Ballast By-Pass / Mod for any Bulb / LED - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 8th January 2013, 06:16 PM   #11
Originally Posted by niljaviya View Post
hi,
i have a same problem , my 3M PJ also has limited opening for LED + heatsink,
but for 100W i am planning for water cooled system,
which will stay outside. only water block and LED will stay in box
curretly with my 30W LED i shave standard pc heatsink to fit in pJ box. after 30-40 minute of it is pretty much 50-55 degree. but won't work for 100W LED.
just sharing idea.
If I use a Liquid Cooler and have the Thing outside. It's NOT going to work in my case. I hate seeing extra stuff around my PJ lol
Anyway, I'm gonne see how I fit it all in once done!
Old 8th January 2013, 11:39 PM   #12
i don't like either extra stuff and cable , water line etc .around pj...but it's all about
DIY cheap cost...fix and self satisfaction of job done.
once you start to watch pj/ movie you will forget everything what is around your PJ
i am also working on mine too...i will post picture soon
Old 18th January 2013, 09:17 PM   #13
OMG, I done it but the Lumens is like about 600
The light Bulb is really bright outside but once you put it in... I don't know where all the lights go
I dunno where I am heading now since it's NOT working the way it should. My PJ seems NOT letting all the lights passes through...
Anyone have this Problem?
Please reply if you do, thankx!
Old 19th January 2013, 12:30 AM   #14
hi,
let me explain something hope that will help you to understand
instead of original lens, in front of LED you have to use collimater lens,
bcoz LED light plate produce scattered light you have to focus all light to one Strong BEAM that one only possible if you put right collimater lens with reflactor.
tomorrow i will post my LED lamp which is 30W LED which is way low, but it is good for experiments. if i would able to take picture of working pj i will post that too.
Old 19th January 2013, 11:29 PM   #15
hi,
Hi, yes i have the collimater lens in
Please tak some pix with yours and let me see... Maybe I can get some ideas... Thankx!
Old 11th May 2013, 01:44 PM   #16
Default Thanks.
Originally Posted by JodBronson View Post
Here is how I by Pass the Ballast for the Sharp XG-MB70X or XGMB70XA
All you have to do is open you Projector and find the Ballast, under the Board with lots of Screws, LOL
Anyway, just solder the Optocouplers like in the Pix and you are all set. Just a NOTE: I tried the 1st one, didn't do anything, 2nd one = no and then I did the 3rd one... All of them and BANG it worked!
I will install an LED BULB in, after done, I will post some Pix with LED in it and also some helpful info...
Hope that this will help someone...
Uploaded with ImageShack.us
Also the Manual on Page 19 is helpful:
http://diagramas.diagramasde.com/otros/XGMB70XA.pdf
I used this method on a Sharp XR-10S-L: worked like a charm, just had a bit of trouble getting to the optocouplers. BTW, they are named D7713,D7714 and D7715 in the list in the service manual.
Thanks!
Old 29th May 2013, 04:31 PM   #17
Also works for NEC LT150z. Just look for three PC123 optocouplers in a row.
DIY Projector Parts FS: ballast, bulb, socket, ikea reflector, and condenser roger_lew Swap Meet 1 28th February 2009 04:52 AM
Copyright 1999-2017 diyAudio
