Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 4th November 2003, 07:09 PM   #11
VvvvvV is offline VvvvvV  United Kingdom
that sheet isn't actually a polarising sheet, it is a refractive layer, that splits the light into 3 directoins, stright ahead and to + and - 45 degrees, so that the backlight makes the lcd visible to people standing next to you, although i may well be talking about different designs that the cmv
Old 4th November 2003, 09:50 PM   #12
Default dude..
I don't know wtf you're talking about but every TFT LCD that I know of has permanent polarizers, one on each side of the LCD panel. You could in theory peel them off but that would be very stupid..
Old 4th November 2003, 10:05 PM   #13
hassler is offline hassler  Australia
I'm glad that nothing has to be removed.
In other threads I have seen it mentioned that some polarizing sheets were removed from other LCD's.
Old 4th November 2003, 10:21 PM   #14
i was confused about this for some time also because i have a laptop LCD that has not only the fixed polaroids that you tell me about on both sides but also two cling film like transparent layers that split the light in a ' Y ' shape from as it comes in the backlighting. the result is two images of the backlight projected on the roof. it is cool plasic, you look through it straight and you can see things beside you. quite shagadelic.
Old 4th November 2003, 10:30 PM   #15
Default errrr
Ummm, often there are diffusers or collimators, usually as thin semi transparent sheets that you would want to remove, but I haven't heard of them being glued to the lcd, altough there may be cases in which they are. If someone removed the polarizers I would like to know how they could get the lcd to work after that, they are necessary for the lcd to function.
"Polarizing filters being a set of very fine parallel lines act to block all light waves apart from those parallel to the lines of the polarizing filter. If you use another polarizing filter at 90 degrees to the first filter you would block all light getting through. So if you now put the twisted liquid crystals between these two polarizing filters the light passing through the first polarizing filter is twisted the 90 degrees necessary to allow it to pass through the second polarizing filter. Apply a voltage to the liquid crystals to align them vertically and the untwisted the light is now blocked by the second polarizing filter. No light gets through."
Old 5th November 2003, 06:06 AM   #16
What is the panel in 1515 monitor anyway? In post #5 it seems to read A150X1 which is the monitor model number. I can see CMO logo printed on PCB but not a LCD type like M150X3 etc. which CMO manufactures (www.cmo.com.tw).
Old 5th November 2003, 06:17 AM   #17
NEC?
http://www.nec.co.jp/press/en/0104/2602.html
Old 5th November 2003, 08:39 AM   #18
the monitor model # is A150X1 - TO5 rev-c
The LCD model # I can't see??
There is a number stuck onto both the horizontal and vertical controller boards: L$U3131-101A
I hope this helps
Old 5th November 2003, 08:41 AM   #19
has braindude said all the codes written on his cmv 1515, ask him perhaps
Old 5th November 2003, 10:21 AM   #20
http://www.hardwareoptions.com/merch...tegory_Code=V2
at this place in the uk the 1515 is 192 pounds or 340 dollars, shipment might be available overseas i dunno.
Page generated in 0.13182 seconds (64.07% PHP - 35.93% MySQL) with 11 queries
