#311 |
cooldrums, i am waiting on my lilliput now it should be here in the next 3 days. I have the fujinon lens. If you want to collaborate on ideas let me know. I am looking to find a source for the cdm-t bulb and ballast.
Thaanks, Jarrett
http://www.jarretttowe.com |
#312 |
Sure I'm open for ideas!
How far do you plan on being from your screen, and what will be the size? 16:9, 4:3 at what width? Not sure what bulb your taking about is it a 250w model? I bought this 400 watt bulb and ballast about 8 months ago before i relized that a smaller bulb would give about the same useful brightness with a little more planning. oh well... |
#313 |
I'm also looking for a source for cdm-t. what are the specifics of what we need? I can do a little research...
#314 |
I'm not sure I'm understanding the cdm-t lighting options...maybe someone can enlighten me?
are these the right components? bulb: http://store.yahoo.com/lidra-sg/hdlp01.html for the bulb. The 150W 4200K bulb is what's wanted, right? Now, I know we'll need a ballast: http://store.yahoo.com/lidra-sg/lfab01.html there's also base: http://store.yahoo.com/lidra-sg/lfahl14.html -- we'll need this also, right? the ignitor: I don't know what to look for in an ignitor can't seem to find one... what is needed? Also, ace, if you happen to read this, will the specs of your light engine be able to handle the 250w MH bulbs? The color temp is the same, but another ~8000 lumens... |
#315 |
Guys thanks for your suport and understanding, much apreciated, as for ideas well i dont own this forum lol even though i made this thread im quite happy for u guys to pass the time and come out with new ideas, its how we all learn from each other and realise of new tech and different things that will and wont work, i have a few new tricks up my sleeve infact im looking at using one for this new projector, it should give us an increase of light with another 40% from the bulb, weather i can get this going or not in time is another factor but ive heard through the ropes that this new light reflector design can give us the same results with the 250w hqi using nothing but the 150w cdm-t, im working on it now so we will see how easy it is to grond or drill 5mm pyrex glass first lol
Trev |
#316 |
I think that ballast I linked to is not appropriate...
#317 | |
As for the search u did on yahoo for the bulbs they are the right gear, they are also abit pricey though, ill do some home work and see if i can get u guys some cheaper in bulk, also the ge bulb is brighter then the phillips but i dont think u would notice much difference. The light engine should be able to handle the 250w hqi, it would probally be at its limit for safe cooling but time will soon tell when i try one in a newly designed light box to fit the 250w, as u can see a few modds are in order for those who want to upgrade from the original model im building now and i think its great as it gives us choices in this design in what we want to use it for and for our budget, i have received 3 reflectors in today after i posted the stress post lol and i can tell u guys u wont be disapointed, they are awsome, for the cdm-t im going to modd one to get its optimum light output, with a 250w hqi this modd isnt needed as the center arc tube is clear therfore the light thats reflected in a shperical reflector configeration can go through it, now because a cdm-t isnt so clear in the center less light can come from the reflector so im doing a couple of modds starting of tommorow and changine the shperical reflector into a parabolic as shperical reflectors can run as both, therfore the light will come out paralelle from the reflector then rather going through the arc tube giving us more light, another thing i have realised is the page maggs arent that good, they use light, they arent the high grade optical acrilic that ohp frensels are, they are tinted and also chew light, as soon as this ohp frensel comes in ill cut it and get it to work, get the settings and make it on that, if all fails i guess the page maggs will be the only way to go as custom frensels are a mint to buy. Trev |
#318 |
Yeah those ballasts are for flouresent bulbs buddy no good for a cdm-t bulb lol but how ever mathias a good buddy of mine made a ballast for a cdm-t using those ballasts in a series circut, run up a search for home made ballast and im sure it will come up, it maybe the way to go for u guys in the us. Those are certianly cheap enough about 5-$7 each, u would need 4 of them.
Trev |
#319 |
okay. I don't plan to power any leds, only to have a 2-3 fans for cooling...I'm not comfortable working with electronics yet, so I'll go as simple as I can. Sounds like I'll get a better sense of how to do that when I get a look at the plans.
I'm excited about all the research you're doing on the optics...can't wait to hear about the new fresnels and reflector. I can't seem to find a ballast, electronic or magnetic, for the 150W cdm-t bulbs, or an ignitor. I remember the thread on the home made ballast...I'll go review it again and see what's up. Might be the cheapest way to go... I am curious about the amount of light being used in the pj .. at what point is it *too much* light? Is that possible? is there a point at which the light starts compromising contrast and darker hues? It seems like we've been pursuing more and more light for so long, I never thought I'd ever ask that question... |
#320 | |
As for the throw right now i have my projector about 3.5m - 4m from the wall, its rough image size is about 107inches diagonal maybe more maybe less, i dont have a whole wall right in this room for it to project on as i need to mount things to the base plate and shift it to another room to utilise a full wall to measure it, but that will be soon, the image evening and tuning is done with a short throw (cos its all the room i got in here lol) and that projects the whole image so i can see if the sides are out of brightness to the center ect. Trev |
| Page generated in 0.14556 seconds (78.76% PHP - 21.24% MySQL) with 11 queries |
