#1001 | ||
#1002 | |
Yess we have discussed the elliptical reflector somewhat. The difference being here is that, i own 3 brand new elliptical reflectors and have tried both the par30 and the ellipsidal reflectors (along with many others) in reality, and hands down, the elliptical wins by a long shot everytime!!! Buy one, you will never turn back .Lcd use both parabolic and ellipsidal, DMD (single chip) will only use ellipsidal. It is impossible with todays lamps to use a parabolic on a single chip DMD system, not unless you have a reflector and light source capable of being 15mm in dia, and parabolics are just too inefficent for a DMD system. http://www.plus-america.com/papers.html The light that goes through the colour wheel is strait from the ellipsidal reflector, after the colour wheel it is condensed (with a condensing system) to parallele light, it then bounces off of 2 front surface mirrors (1 concave, 1 flat) angled at 12deg, and then reflected off of the dmd through the lens. Any light that isnt reflected through the projection lens (when the pixel is turned off) goes strait to the roof of the light engine. Trev
"Every technique can be used in a great many ways, but mastering it, thats what realy counts." |
#1003 | |
Lcd's use a fixed colour system in which the only thing you can control is gain. The colour of an lcd is off with our lamps because of the colour shift in the polarisers.............. which cant be changed other then changing the lamp, or filtering the light externally to a higher colour temp. Trev
#1004 |
Hi Ace
Im new to this diy projector thing so bear with me if this is a noob question =) I've been reading most of this thread but haven't been able to see why use choose to place a mirror in your projector. IMHO I would have thought that using an arrangement without the mirror would equal less light going to waste. Something like this: arrangement I can see that almost everybody building a 7" projector uses the same arrangement as you do so I guess there's a good explanation. I guess this has already been mentioned so if you could point me in the right direction that would be great.. Also I stumbled opon this beauty in the german diy-community: Link I can see that it's been a while since you've put some photos in this thread so thought the people following your progress needed something to keep up the drooling =) Nice work on your projector BTW. Best regards Søren W. |
#1005 | ||
Heya Soren, welcome to the forum
, thanks for the nice words aswell. The reason i used a mirror is simply because of form factor. Rather then having somthing very long, we can make it into a flat square , or compact if youd like. The loss from fs mirrors isnt great at all, (if noticeable) providing you use fs mirror of reasonable quality. Try to get somthing thats 98% reflective, that way there is only a estimated 2% loss per mirror.Quote:
![]() Trev
#1006 |
Hi Trev
Thanks for the reply.. As I mentioned I'm new to this so for my first projector I'm looking at constructing something as simple as possible.. I really like the idear of the one I linked to as it is all adjustable. But I'm still just researching and will probably be doing so until the winter as I've got some other projects that need some attention before I start a new project... Anyway I've read that you are able to supply most of the stuff that is needed to constuct one of these 7" projectors so if you could drop me an e-mail at sn1009@gmail.com with a list of the stuff you stock that would be great. Thx Søren W. |
#1007 | |
. Take your time and you will have a winner. Trev
#1008 | ||
Yes I know how dlp works, in fact very good. The on off timing of the DMD mirrors you are talking about, is just a simple DA-converter for light. Do you know what PWM is ? If you want to control the lightlevel of a lamp or the speed of a DC-motor you normally use PWM. PWM and DMD are the same thing a "digital to analog-converter". When itīs come to colour, lcd and dlp are the same thing: A colour filter. What you canīt do with lcd, you canīt do with dlp. DMD canīt do magic things, itīs just normal mirrors. Take a normal desklamp, what colour filter can you use to get the lamp whiter ? If you can change the colourtemp with a cold mirror or not, I will leave that unsaid, but I wonder HQI donīt have much IR.....and you donīt use a cold mirror in the dlp-projector ? Quote:
#1009 | ||||
. A heatsink should ring a bell............Some pro projector lights do actually have a IR filter installed, infact most do, why? not cos of the temp of the dlp chip, but because of the bearings on the colour wheel. The Infocus X1 had a big problem with this, where the bearings on the colour wheel would overheat and fail. And thats why Infocus tells you not to run the X1 any longer then 4hrs. Quote:
Perhaps it would be wise if you went to the site i posted a couple of posts back and read the white papers on DMD, DMD's are digital DMD = Digital Micromirror Device http://www.dlp.com/dlp_technology/im.../131_vproc.pdf Trev
#1010 | ||
| Page generated in 0.18173 seconds (82.95% PHP - 17.05% MySQL) with 11 queries |
