Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 24th November 2003, 01:21 AM   #11
Just happened to be passing... I quit DIYP a while back to go travelling and saw this post.
Another possibility. The following is a schematic for a DB25-DB15 converter cable that I made for a 3m5300 panel. You might want to try it out (with a HD26, of course) if the previously suggested schematic doesn't work.
FYI, the schematic came from service docs for the Ovation 810c panel. It took a LOT of research to find!!
Click the WWW link below for my DIY Projector pictures
Old 1st December 2003, 02:43 PM   #12
KasaK is offline KasaK  Dominican Republic
Hi guys. I came back with good news. I just builded both cables and both worked perfectly; both pinouts worked for my projection panel (the panel did not burned ut).
Thanks vinyljunky for the diagram provided, it smoothly too.
Finding the HD26 connector was a little bit difficult, but I found it.
Thanks for the support guys.
Old 1st December 2003, 07:12 PM   #13
was wonderng where you found 26 pin i didnt have any luck
Old 15th August 2005, 06:58 AM   #14
I have a 3m 6150 lcd projection panel with the same db-26pin cable. do you think your cable pin out will work for mine?
Old 5th November 2005, 06:44 PM   #15
Waldorf is offline Waldorf  Poland
Will it work with 3M 4850 ?
Old 7th November 2005, 01:49 AM   #16
haven't had time to test it out on mine yet.
Old 7th November 2005, 07:07 PM   #17
Send a message via ICQ to draven66
Default 3m 6450 power cable
I have recently acquired this 3M 6450 panel and will use the svideo input, but it didn't come with the necesarry power cable. It looks like a 7 pin DIN connector but i have no idea where to find or how to build this! The unit requires 15V DC which I can find but the wiring is gonna be a doozie. I see 6 pin DIN connectors but 7 pin! anyone??
Old 9th May 2011, 05:04 PM   #18
Hi guys. I bought a used 3M 6450 projection panel for my rear projector. But didn't include the power cable. Draven 66 had the same problem. Did you manage to find a solution? Is it possible to build a power supply for this unit? How should it be wired?
Page generated in 0.10196 seconds (76.94% PHP - 23.06% MySQL) with 11 queries
