Go Back   Home > Forums > > > >
Spherical Reflectors
Old 3rd May 2012, 07:12 PM   #1
eponymous is offline eponymous  United Kingdom
Default Spherical Reflectors
Hi all,
I wonder if any of you can help me with this.
I've purchased this reflector:
G&P Optoelectronics GmbH & Co. KG - Reflector 68mm f=40mm dichroic 06-04-02 (is this perhaps the same as the LumenLabs Pro Reflector?)
diameter: 68 mm
focal length: 40 mm
I'm wanting to see if it will work ok with an Osram Powerstar HQI-TS which has a radius from the centre of the bulb to the outer edge of 16.5mm.
As this is a spherical reflector I assumed that I should place the bulb at the centre of the effective sphere which is actually 25mm from the back of the reflector - not 40mm!
How can the focal length be 40mm if the centre of the sphere is at 25mm?! Am I missing something here?
I've attached a diagram to show what I mean.
As I only seem to have 5mm from the edge of the reflector to the bulb centre I don't think this will work. Does anyone have any ideas?
Thanks!
Old 3rd May 2012, 10:08 PM   #2
I've also attached a picture showing the bulb. It is so long that it can't fit inside the reflector.
If I put the reflector right up against it, the centre of the bulb is still (16.5mm - 5mm) = 11.5mm too far out from the reflector's focal point
Old 4th May 2012, 08:13 AM   #3
TESCORP is offline TESCORP  United States
TESCORP's Avatar
This is the same reflector as Lumenlab had and I have in stock as well, the focal length is 40mm as this is a portion of the sphere and not a hemisphere. The best way to place the bulb is to move it forward or back from the reflector until the image of the arc chamber fills the reflector while you look at it from the front (around 40mm). You will see what I mean as you do it. You have plenty of room without having to move the bulb so close to the reflector.
Old 4th May 2012, 08:39 AM   #4
Thanks for your reply Tescorp. It's also good to know there's another store out there since LL went away
So I'm a little confused still. I realize this is not a hemisphere so what I did was draw an outline round the reflector on paper. Then I used a compass to draw a complete circle which followed the same arc as the reflector.
The circle had a radius of 25mm and that's where I got that value from.
Is that not correct?
Cheers.
Old 4th May 2012, 11:07 AM   #5
Incidentally if I put my finger at 25mm it does seem like the image reflected back fills the whole reflector.
Can I see the reflector you have to see if it's exactly the same? I'm guessing it is as I doubt there are many places you can get these dichroic ones of that diameter...
Old 4th May 2012, 08:31 PM   #6
I did some experimentation and have attached photos. I'm now fairly convinced this isn't a 40mm focal length reflector. It's more like 25mm.
So now I'm wondering why LL/G&P etc are selling this and claiming it will work with the larger 400w bulbs which are far too large..
I've attached some images. The first one shows the bulb reflection at 40mm, then at 25mm and the last two are how I'm trying to use the reflector.
Old 5th May 2012, 10:21 AM   #7
Ok I think I see the problem here.
This reflector is being sold as a 40mm Focal Length reflector of diameter 68mm.
However, the focal point of spherical reflectors for DIY projector builders is of little interest.
Remember that the focal point is where the light rays will emerge parallel from the reflector if a point light source is placed there. We don't want this.
We want to know, what is the the radius of curvature for the reflector (the radius of the sphere the reflector is a section of).
That 40mm advertised focal length is actually the radius of curvature I think and this is indeed the point where we want to place our lamp so that the rays reflect back directly through the that point.
This means the focal length (= 1/2r) should be advertised as 20mm. At 40mm it should look the same but upside down.
Old 6th May 2012, 07:50 PM   #8
TESCORP's Avatar
I did a drawing for you to show how I place this reflector to my bulb, hope it helps!
I also attached a few pics of stuff I have done.
Old 6th May 2012, 07:52 PM   #9
Some nice ideas there
Yep your picture is exactly the same as mine hehe
Spherical ReflectorsHide this!Advertise here!
Spherical Arrays...? klocwerk Multi-Way 18 5th May 2007 10:08 AM
Spherical horns AuroraB Multi-Way 17 10th October 2006 03:32 PM
spherical enclosure MrSensitive Subwoofers 94 6th March 2006 08:06 AM
