Go Back   Home > Forums > > > >
'new' keystone adjusting idea
Old 17th February 2004, 12:00 AM   #21
Cybergent is offline Cybergent  Germany
Every professional video projector is projecting off axis for easy floor or ceiling mounting.
But this is not made by tilting the projector and correcting the misaligned picture by keystone. It is made by putting the lens off axis by some offset.
This is also called lens shift.
The projector then stays in the horizontal position.
Keystone should only be used if it is not possible to install the projector in a horizontal position or if the screen is not absolutely vertical.
Best Regards,
Cybergent
Old 17th February 2004, 12:42 AM   #22
ace3000_1 is offline ace3000_1  Australia
ace3000_1's Avatar
Send a message via Yahoo to ace3000_1
My projector had a lens offset and a up and down to move the unit up and down aswell as a keystone. The lens was off axis by default so u didnt have to tilt the projector as high.
And this offset is done with a frensel cut offset with an offset mirror to guide the light through the lens
Trev
Old 20th August 2005, 08:49 PM   #23
dracul is offline dracul  Brazil
ace ,
can you explain this a little better. speak simple english.
1900x1200 All the way baby!!!
Old 2nd May 2013, 10:40 PM   #24
cyberdevilnl is offline cyberdevilnl
First of all, sorry for waking up an old topic.
This is my idea of keystoning, as what I'm reading from the posts above it should work, can anyone confirm this?
'new' keystone adjusting ideaHide this!Advertise here!
Keystone CL-60...How Hot Should It Get? Mark A. Gulbrandsen Pass Labs 20 3rd December 2006 05:39 AM
Copyright ©1999-2017 diyAudio
