Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 25th August 2010, 01:36 PM   #21
It's hard to say whether the existing circuit (without seeing it) wouldn't have any problems at such a low duty cycle, even at such reduced power.
*second edit*: Well, depending on what you fed from the original ballast board it wouldn't need to run out of normal range anyway..
Do you intend to use HID or LED, and are you thinking of using the existing board as the only ballast, or having it feed another one with input voltage dependent output?
I think the LED ballast would be much simpler, not even any starting mode.
Old 25th August 2010, 01:45 PM   #22
With optics and firmware designed for filament illumination, would it be difficult to get the right color balance with an LED source?
Old 25th August 2010, 07:29 PM   #23
From the LED mods I have done this really doesnt seem to have any effect. The optics are happy as long as they get light. The origional lamp was Metal Hallide not filament.
Old 3rd September 2010, 03:22 AM   #24
just curious as to which projector you used for this mod? im very interested in this to say the least.
Old 9th September 2010, 12:45 AM   #25
Check out some of my other posts or see projectionforums.com where all my future projects will be..
Page generated in 0.09191 seconds (68.51% PHP - 31.49% MySQL) with 11 queries
