#11 | |
jd
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#12 |
Here is a signal from the tx and rx of the microprocessor. It looks to have alot of noise but this is the signal going to the opto-couplers
![]() Here is a picture of the ballast and input wires. Wires are as follows:
#13 |
![]() Here is a picture of the ballast and input wires. Wires are as follows: RED - Signal Back to Projector From Ballast WHITE - Ground BLUE - +5v YELLOW - Square Wave CLOCK BLACK - Signal From Projector To Ballast ![]() This is where I get confused..... The bottom 2 optoisolaters are for input. The middle one being the clock signal and the lower one being the serial information to the ballast. I was looking at the data sheet for the isolaters and tracing the circuits. http://www.datasheetcatalog.org/data...shay/83666.pdf The top pins get +5V from the blue wire The signal lines go through 100 ohm resistors and to the bottom pins(Most likley current limiting) The other side of the the lower optocouplers feed into the microprocessor on the rx and clock lines On the return the microprocessor feeds ithe tx output into a transistor then to the optocoupler and back to the board The signals I meaured from the pins of the micro processor are not at all what I expected. The signal looks really noisy I am thinking maybe I could cut out the micro processor and just bridge the TX and RX traces but I'm not sure it would work Last edited by crazifunguy; 23rd August 2010 at 10:00 PM. |
#14 |
I decided to desolder the ballast controller from the actual ballast. I got some high rez scans of both sides. Unfortunatley it is a 4 layer circuit board. I am going to try to trace the circuit paths and create a block diagram from input to output. This might take a few days to complete.
Front Side ![]() Back Side
#15 |
#16 |
Well I managed to get a copy of the "Holy Grail" for this projector....AKA the service manual. Its funny that you were talking about using a PIC to communicate with the ballast. This projector uses a PIC to control all ballast functions.
After studying the schematics and trouble shooting. I figured that the Lamp_Err signal coming out of the PIC was the place to start. This signal is around 70mV and jumps to 5V when a lamp error is detected. This signal is sent through a buffer IC then to the main processor. http://www.fairchildsemi.com/ds/74%2F74LCX541.pdf By cutting the trace from the pic to the buffer and connecting the buffer pin to the buffer ground the projector stays on.... SUCCESS!! So far anyways. I havent tested for more than 2 minutes. I dont know what repeated errors will do to the pic or any other part of the circuit. |
#17 | |
Better to find someone who is good at it already. And don't forget you need to figure out the whole control logic structure first! jd
#18 | |
jd
#19 |
I just wanted to mention, if you're not careful, with that much of the plate through hole stuck to the ballast pins and a four layer board you could easily wind up with some discrepancies between what you see in the drawing and what's actually wired on the main board..
#20 | |
Oddly enough these ballasts do not have a set wattage rating. The wattage is variable down to 0% now if through the service menu if the power output is lowered down to say 15% would the ballast still function and would it power a 35w HID lamp and not explode? |
| Page generated in 0.12739 seconds (86.44% PHP - 13.56% MySQL) with 11 queries |
