Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 10th March 2010, 03:29 AM   #1
Default Possibly The Brightest DIY LED Commercial Mod
I've been playing around with LED's specifically Luxeon Rebel Led's I took one of my Proxima DP8000 projectors and hacked it up just to see what I could do. I used 9 LED's 3 of each color mounted on a chipset heatsink. I bypassed all of the light engine junk and color filters. The LED's shine direct to the polars of the LCD's I am running them at 1000ma.
Taking measurements the projected size was 60 inches and I measured the output between 480-520 Lux with a white image projected. Some pictures are attached. This is just beta testing I am looking for a better projector to use these LED's in.
Old 10th March 2010, 12:51 PM   #2
ywh is offline ywh
Send a message via MSN to ywh
great!
can you show your LED? please remove the LED lens to take picture.
you will get great picture if you can use a normal digital camera , but not a mobile
Give up the UHP and HQI lamp now! Take a look at our LED projector!!http://www.diyaudio.com/forums/diy-p...e-theater.html
Old 10th March 2010, 06:56 PM   #3
This is seriously awesome
I've been waiting for some time to see someone use 3 LEDs for each LCD (as I recall the idea having been thrown around here a short while ago)
You do realise that you're going to have to do a full analysis of what you did (ok, so you don't HAVE to, but it would be great)
But that is very impressive
Nicely done!
Old 12th March 2010, 05:54 AM   #4
This was basically a proof that It would work. The Optics I choose where actually focused too tight for the 1.3 inch LCD's I either need a projector with smaller LCD's or different lenses. The image was very bright with the setup but the edges suffered. I had no idea what my lumen output was I could watch it with a light on tho.
Here are a few more details.
Power input 3Amps
Lumen Input - 969 Lumens
R-255LM
G-540LM
B-174LM
The lenses are about 90% efficient so I figure I am getting about 870 total lumens in. If the LCD panels are only 25% efficient I should still get around 200 lumens output.
I will be ordering a more efficient projector and performing this mod. I have about $125 in materials so far but with a 50,000 life on the LED's its worth it.....More to come soon!!
Old 12th March 2010, 05:59 AM   #5
For YWH.....They sure are TINY!!!
Old 12th March 2010, 01:35 PM   #6
ywh is offline ywh
what is the model of this LED?
Old 12th March 2010, 05:03 PM   #7
Luxeon Rebel
Old 12th March 2010, 05:14 PM   #8
Like I said, I had heard about the concept before (and it was most likely you that pitched it) and I had seen something similar from Phlatlight describing how hey would use a similar tech of 3 Leds
But I am quite amazed. Literally. The fact that much brighter LEDs are available and these are the results you're getting so far,I am very impressed
Looking forward to more details
Old 29th April 2010, 02:56 PM   #9
Hello , i found the LEDd that you use but i am more interested which lens are you using ? Narrow ,medium or wide ?
I am really impressed of your experiment .
What is happening with the color balance when the LEDs are different in power .
is there an option to balance the image of the projector throw the software so not loosing any power .
Thanks in advance .
Great job and good luck in the future experiments.
Old 29th April 2010, 05:46 PM   #10
This is AWESOME. I've always enjoyed your work CrazyGuy. I'm thinking that this can be vastly improzed using the same method but on LCoS but they are just too dear. How bright is it? I've actually got a Toshiba LED DLP projector (TDP-FF1A). Have attached it so I can show off this beauty. Been meaning to open it up and have a nose inside but just can't make the time these days. That Toshiba pushes out 35 Lumens. Not good for movies just the odd presentations. What do you reckon your mod does?
Commercial or DIY amps Dr.EM Solid State 48 20th May 2008 06:12 AM
toggle switch with LED on tip for t-amp mod? gychang Class D 4 18th September 2006 05:54 AM
How do DIY speakers compare to commercial? nrgy Multi-Way 21 24th September 2004 06:40 PM
Page generated in 0.10286 seconds (79.47% PHP - 20.53% MySQL) with 11 queries
