On every where I look, it says that SHP is low voltage DC and NSH is high voltage DC.
Most places i've researched say low voltage bulbs have the lead wire twisted on top portion of bulb and high voltage bulb doesn't or just has one twist on top portion of bulb. Then why has my Infocus LP600 (200W SHP) has one twist and my HP VP6121 (200W NSH) has lots of twists on the top part. Does that mean that SHP is actually high voltage whereas NSH is actually low Voltage ignition? |
#2 |
SHP: some one is low Voltage ignition,
NSH: high Voltage ignition, take a look the ballast, that is high Voltage ignition if there is a FLY BACK TRANSFORMER
Give up the UHP and HQI lamp now! Take a look at our LED projector!!http://www.diyaudio.com/forums/diy-p...e-theater.html |
#3 |
If NSH is high voltage ignition, then why is it that the original lamp in a HP VP6121 has a lot of windings on the top portion?
#4 |
a lot of windings can help ignition, every burner have windings
| Pass X250.5 Voltage Change Confusion | Jazzo | Pass Labs | 20 | 18th June 2009 08:38 PM |
| Voltage Gain Confusion!! | apehead | Tubes / Valves | 6 | 6th November 2007 02:47 AM |
| ignition thing | shalashaska | Car Audio | 0 | 24th December 2006 08:01 PM |
| Ignition Noise | sandyhooker | Car Audio | 10 | 27th April 2006 04:06 PM |
| Page generated in 0.07241 seconds (73.13% PHP - 26.87% MySQL) with 10 queries |
