Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 23rd June 2009, 02:16 PM   #1
Send a message via MSN to chinajin9999
Red face LED+FLYEYES+COLLIMATOR=LED projector
Hi, All
I have been in working on led PROJECTORS for years. Now I found the best way to make an LED projector.
1. a true LED projector with only 19 watts CREE XLAMP LEDs
2. the efficiency is more than 85%,and the uniform is more than 80%
3. The brightness is better than ALLY PTV01, MUCH MUCH BETTER. But to speak truth, the brightness is only 150 ANSI lumens;
4. The image is good. You can see the following pics.
Old 23rd June 2009, 08:46 PM   #2
can you post some projected images and pictures of the internal of the projector that uses these LED's?
I'd like to see the uniformity especially
Thanks!
Old 24th June 2009, 11:50 PM   #3
What are the mechanil dimentions
length , whidth?Is it RGB module or white one.Emiting angle of each led.What kind of metal is the PCB , aluminun or copper.Thank you.
kb
Old 26th June 2009, 03:18 PM   #4
Default About the collimator
The width=69mm, the length=79mm;
I use the cool white LED from Cree, Q4, and Bin=WA,WK, and WB&WM is also good.
the emitting angle of Q4 from Cree, is 90 degrees. My collimator can collect 85% of the lamps. The efficiency is much much higher than other so-called engine.
I use the Heat-pipe cooling system, and the Aluminum MCPCB.
Old 26th June 2009, 03:18 PM   #5
Default the image of my led
the uniformity is more than 85%
1. the middle, lux=86
2. the corner, lux=64
3. the ansi lumens, more than 140 lumens
Old 26th June 2009, 03:18 PM   #6
Default More images
Please see the following attachment.
Old 26th June 2009, 03:18 PM   #7
Default To design the engine
The following attachment is my design paper.
You can find that in this engine,
I have two flyeyes lens, and one collimator, and one object lens.
They work together.
Old 27th June 2009, 12:23 AM   #8
Thanks,for your reply, very profetional .The 79mm lenght ,does it include the heat sink + led module +all the lenses?The reason for asking is , can that module be fited inside projector.My two projectors are more than 79mm long,but i'm not sure ,whether you mean 79mm total(all components).Is it this module for lcd or dlp?
kb
Old 27th June 2009, 05:11 PM   #9
that looks really nice indeed! It would be great if you could post some pictures of the actual projector, the insides of it as well as some images
The fly eye lens seems quite interesting indeed. Also, using Q5 LEDs could increase brightness as well
Thanks for the posts!
Old 29th June 2009, 02:34 AM   #10
hi
Look, this is what the engine is.
The dimensions of the engine is: 20CM*20CM*10CM(W*L*H).
The LCD panel is there, I use the 5" 800*600 LCD panel.
yes, I can use the Q5, but, for Q5, the color temp bin= wa/wk can not be found. so, Q4 is better, though it is 9% less brighter.
check it.
FS: Projector Parts - Overhead Projector, lenses, mirrors, + more Moose Swap Meet 4 27th November 2005 09:37 PM
Page generated in 0.12312 seconds (64.61% PHP - 35.39% MySQL) with 11 queries
