LED:
Forward Voltage VF IF=3500mA 32-36 V Flux Characteristics ¦µv IF=3500mA 6000-7000 lm Color Temperature Tc IF=3500mA 6000-7000 K Viewing Angle 2¦È1/2 IF=3500mA 110 deg LED special power: Constant Current Source (not normal Switching Power Supply ) cooler.: pure copper base and 4 heat pipeS condenser diameter 75mm. focal length 70 mm
Give up the UHP and HQI lamp now! Take a look at our LED projector!!http://www.diyaudio.com/forums/diy-p...e-theater.html |
#2 |
total is $280
#3 |
Ywh,
Have you used this lamp assembly in any projector? If so, have you any screenshots to share? |
#4 |
from some friend
#5 |
Wow! That is pretty impressive. How big is this thing?... I am seriously thinking about getting one.
#6 |
5" LCD and 92" screen
#7 |
#8 |
#9 |
Does the heatsink get very hot or is it more then enough to run this huge LED?
#10 |
Hi DrFrekkr !
yes! the heatsink get very hot and the enough is 100w . it can get 55Celsius if you choose this cooler
| Search fan cooler for the KSA 100 Mk 2 | Alex helge | Solid State | 0 | 18th September 2006 11:37 PM |
| noise from a cooler (two different ones) | facundonu | Chip Amps | 12 | 6th July 2006 01:09 PM |
| peltier cooler | karma | Swap Meet | 6 | 5th December 2005 01:55 PM |
| Fan cooler for JLH 10W a-class | adirax | Solid State | 3 | 15th May 2004 11:21 AM |
| CPU cooler for amplifier | Circlotron | Solid State | 16 | 27th December 2002 11:58 PM |
| Page generated in 0.09795 seconds (74.21% PHP - 25.79% MySQL) with 11 queries |
