ok so i read up on some of the other threads in regards to this topic. So i tried it, here is the outcome
Removed ballast and found 5 small wires going to board from ballast. I disconnected this set of wires and ground each pin to see which would leave pj on and by pass the ballast. Pin 1 = No Lamp error code Pin 2= PJ stays on, color wheel spins, looks like its working but no picture and then gives Replace Lamp error code. Pin3= Same as pin #1 Pin4= Nothing. Power light comes on but does nothing else, when i remove the ground PJ starts up and then No Lamp error code again. Pin5= Same as Pin #1 When i do ground Pin 4 after PJ powers up i see a very slight spark and then the PJ stops everything but stays powered on...... Anyone have any similar outcomes. Any better ideas? Now this is all grounded, do you think i have to jump Pins 2 and 4 together instead? Please help!!!!! |
#2 |
One other thing to note is that some projectors use electronic sensors to detect whether or not there is light. I've only seen it on a few, but maybe that could be an issue?
6/12/06: Redesigning everything, finally putting in the Ushio S400DD. |
#3 |
Yeah I already tried that too. I used an external power supply and installed the original lamp housing and new alt source lamp figuring it had to sence a light to go but to no avail.
#4 |
i face the same problem.
it happened when i change the new OEM bulb. The bulb is tested to other projector (different brand and model) and work well. |
| Page generated in 0.07159 seconds (77.69% PHP - 22.31% MySQL) with 10 queries |
